Question about Canon NP 6050 Copier
Error Code E005
I changed the white cleaning web but I still keep getting the same error code. I cannot use the copier.
  • william galaini Sep 07, 2007
    INFORMATION NOT COMPLETE.
  • 62 Answers
Have to reset the cleaning web counter and error. Press *, 2&8, * to enter service mode. (*28*). Highlight COPIER, select COUNTER, select MISC. select CLEANING_WEB and press C on the keypad to clear the counter. Press reset to get back to main service menu, highlight FUNCTION. Select CLEAR. Highlight ERR and press OK. Switch machine OFF/ON. Hope this helps, let me know?
Posted on Sep 05, 2007
  • Bleddyn Jones Sep 08, 2007
    Please tell me which information is incomplete and what your machine is doing.
SOURCE:
E005 ERROR RESET CODE
E005 code is the fuser cleaning web out. Change the web to get rid of the code.
Dec 09, 2010 | Canon imageRUNNER 5000 Copier
Ir 405 copier code as displayed e005. but what is problem i am changed web roller but still e005
Hi
Error E005 means the fuser cleaner roller has run out & may need a replacement. If the error is false it will disappear by following the reset procedure. To clear this error code press * 2 and 8 * in that 2&8 are pressed simultaneously. Go to the web counter and clear the counter back to Zero (0). Machine will now restart your machine & error code will disappear. If this doesn't help then try clearing both web counters in service mode, COUNTER>MISC>FIX-WEB> and COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode FUNCTION>CLEAR>ERR>. Hope this helps... Daniel
Sep 30, 2010 | Canon imageRUNNER 400S Copier
Error code of E005
A E005 code means that one or both of the cleaning webs need to be replaced and there counters need to be reset. Also, maybe the web out sensor flag is out of place
Apr 25, 2010 | Canon CLC 1120 Color Copier
I want to get some help about canon np6050 error
Hello jig,
I wish to help you quickly as you are down. I dont have immediate access to the older analog service manual and Canon no longer keeps it on their website.However, E005 has been a common error code for many products, if not all. It means that the cleaning web (which is an item that is "used/consumed "normally as the copier is used.) has run out.The copier should have been diplaying (in small letters on the dispay) "WEB LOW" for quite a while.It needs a new cleaning web.An untrained end user could change this but without instruction most people would not be able to. Its located in the fuser area onder a yellow cover. I bet you can do it !
Apr 09, 2010 | Canon NP 6050 Copier
I am getting error code e005 0100 how do i reset
E005 Error code details
  Main Cause The fixing web has been taken up. The fixing web length sensor (PS45) is faulty. The DC controller PCB is faulty.
Mode of Detection
 0000 The length of fixing web that has been taken up is in excess of the specified length.
Caution After replacing the fixing web, be sure to reset the two web counters in service mode: COPIER>COUNTER>MISC>FIX-WEB and COPIER>COUNTER>DRBL-1>FX-WEB.
Sep 04, 2009 | Canon CLC 1180 Copier
E005 0200
That is the problem with your copier, you neeed to reset the error code in service mode. And You need to replace both of the cleaning web, the upper and lower web. Good Luck
Jan 13, 2009 | Canon CLC 1110 Copier
Cannon 1150
Get in the service menu, press * 2 8 *, choose COUNTER, reset all counters to 0, go to FUNCTION/ CLR/ ERR, press OK. Turn off the machine and then on.
Apr 11, 2008 | Canon CLC 1150 Color Copier
CANON GP 335 E005 problem
We have fiqured out that the cleaning web needs to be changed therefore we have successfully done this but the error code E005 still appears.
Oct 04, 2007 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
Canon NP 6050 Copier Logo
314 people viewed this question
Clive
Clive
old marine
old marine
Ekse
