Question about Admiral AW22 Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I have a two year old Estate washing machine model TAWS800JQ1 it will fill and agitate through the wash cycle but will not drain, spin or rinse in any mode (delicate, pera press or normal). The lid switch is functional, the pump and impeller are fine. The motor and coupling spin easily by hand both directions. I'm not sure if it is the timer or the motor, any suggestions will be greatly appreciated.
  • Anonymous Mar 31, 2014
    Model number is TAWX700PQO Whirlpool Estate washing machine.
  • 291 Answers
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Posted on Oct 12, 2007
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
Estate Washer (top loader) by Whirlpool. Model Number: TAWS800JQ1 Water will not drain from machine after ten minutes through rinse cycle. It just stops (just shuts itself off) What do we do??
Most likely it is your pressure switch. Locate the switch on your machine and look for damage. if you have a multimeter use it to find any electrical issues if there is no reading the pressure switch needs to be replaced.
Jan 29, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer stops after the tub fills, agitator and tub do not spin
Your lid switch is bad. If you give model number I can give you the part number you need.
May 18, 2009 | Whirlpool Washing Machines
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
How can I tell the age of my washing machine?
I would have to say from looking up your owners manual and the copy right date it is about a 2000 model.
Jan 04, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
HELP PLEASE
you need to check the pump you may have something stuck inside look there first
Mar 28, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
ESTATE TAWS800JQ1 WILL NOT SPIN
both of your problems are the clutch assembly if you are handy you can do this repair
Dec 04, 2007 | Estate TAWS800JQ Top Load Washer
Admiral AW22 Top Load Washer Logo
433 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
