Question about HP Compaq Presario V2000 Notebook
Ethernet not working! Help!
Ok, I've been using a Compaq Presario V2000 for the last 2 1/2 years and its been nothing short of a Great computer... My problem is that my Ethernet port is not responding, even the LEDs inside the port aren't flashing... The wireless internet still works, but I am out range to use it... Please help!
    President:
  • 2,961 Answers
Im assuming its not dissabled, if not then go to control panel, network connections and right click on your network card and go to properties then driver and see if there is a code 9 meaning it's faulty or the device is working. if it is faulty then it's part of the motherboard anyway and you will have to buy a pcmcia network card and connect through that instead
Posted on Sep 04, 2007
SOURCE:
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 PC Notebook: All ports are "in use" with nothing connected. I c...
Click on start. Then click on Run.
Type in MS config.
Uncheck load startup Items.
click on ok and then click on restart.
Any application which turns on and starts using your port when the computer turns on would stop loading on their own and you will have free ports to use.
May 17, 2010 | HP Compaq Presario V2000 Notebook
My ethernet won't work
if it is intel ethernet go to www.intel.com/design/network/drivers/
Mar 19, 2009 | HP Compaq Presario V2000 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Unmounable boot volume
This is an operating system error, and you will need an operating system disc. You can try to repair or reinstall the operating system, but most likely the hard drive has failed and will need replacing.
Jul 19, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Drivers for HP Compaq Presario V2000 laptop
pls send compaq notebook presario v2000 audio driver
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Computer will not start
Disconnect battery and unplug from power, test for voltage on power cord and re-insert, hold down power switch. If nothing try battery without power cord. Still nothing (no lights, no sounds) then it may need system board replacing.
Sep 19, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
98 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
