Question about Lexmark X4270 All-In-One InkJet Printer
Printer not printing right
I replaced the black ink cartridge, now the printer will not line up and also prints words or lines all over the page in the wrong place. Please help.
  • Anonymous Dec 02, 2007
    I work at TechForLess, I am a test technician. I have tested two of these printers with the problem described, sometimes the text on my test page is out of allignment by a millimeter or two, other times there are pieces of text floating in whitespace and I can't identify where it even came from. Tried 3 different cartriges, no change.
    The allignment page prints fine, copies work.... I suspect aproblem with USB connection
    Sergeant:
  • 390 Answers
Try unistalling these beasts and reinstalling with original drivers, then run all the allignments, ink replacement level settings and printhead cleanings again and try to print again.
Posted on Feb 14, 2008
SOURCE:
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Printer smears l h side of envelope Not in printed area
The problem you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge. You can fix this problem with one of 2 ways.
Please select the "Black" only option following the steps given below:
1. Click on "Start," "Control Panel" and click on "Printers and Faxes."
2. Right click on the "Lexmark printer icon" and select "Properties."
3. Select "Printing Preferences," click on the "Quality/Copies" tab and choose "Print Color images in Black and White."
4. Select "OK."
You can also change the color of your text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink please try the following:
2. Select "Clean and Fix Horizontal streaks." This will produce a printed page.
Aug 20, 2009 | Office Equipment & Supplies
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
The printout has lines going through the pictures or wordings
here is the troubleshooting steps
try to remove the ink cartridges and put it baack again but make sure to hear a click sound when you put the ink cartridges,after that try to print again picture and if still has lines through it press the menu in the printer scroll down until you can see the calibrate printer,press ok and select the print calibration page and hit the ok button..after it print place the calibration page in the scanner glass and press start, try to print again a picture and if still has a line call the kodak hot line 1 800 421 6699 and you might have a printhead replacement.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer Problems
Hi Terry,
It's hard to imagine software being the problem, however, I never say never.
Have you tried the BOLD [B] tab in word?
Right click on the printer in control panel, select properties, advanced, and see if there's a contrast adjustment or print quality, select BEST
USUALLY this only works with laser printers, but it might be there.
Open the HP Tool Kit and select ALIGN CARTRIGES, and CLEAN PEN, if it's there.
Click start, run, type in wordpad, press enter, type something and print.
Please let me know. I'm stumped!
Sep 22, 2008 | HP DeskJet 6122 InkJet Printer
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
Incomplete lines
Replace Black ink cartridge with New HP one, should print same problem in write too if this is the right fix
Nov 21, 2007 | HP PSC 1610 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
