Question about Sony KV-32S20 32" TV
No Green in picture
Video is still viewable - with some blue/purple lines scrolling through at time. Looks like we lost the green color. Where do I start to get to the cause?
    Genius:
  • 1,694 Answers
KV-32S... and KV-32V.... notorious bad picture tube.....
not worth pursueing..........................T.
Posted on Dec 18, 2007
SOURCE:
No blue green yellow like in football peach color flags thrown peach color grass is blue green purple color is black etc etc
Are you using a component video connection (3 wires for the video, colored red, green, and blue)? It sounds as though you are, but correct me if you are using a different connection as the steps will be different. If so, ensure that they are all connected. You can also unplug one at a time while watching the picture. If the colors DON'T change when unplugging any individual wire, then check that wire from end to end looking for cuts/corrosion/etc... If necessary, replace the cable. Also make sure that they're plugged in to the right jacks, they should be color coded. NOTE: there is a red jack for the video AND for the audio. Check carefully that these aren't mixed up.
Nov 08, 2013 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Looking for a wiring diagram for a garmin gtm 20 traffic receiver. A couple of wires pulled loose.
Just so happens that my connector lost the red and purple wires, so the picture you have was a great help. Looking at the connector, the wire colors are red, purple, yellow, blue, black, green, brown.
Aug 13, 2010 | Garmin GTM 20 Lifetime Traffic Receiver...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
Wavy picture with blue and purple color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have sound but the picture is purple and will not adjust with the remote or manually with the buttons on the tv what can I do to fix this on the philips 36pt41b129
The unit has lost its green video information. This can be a picture tube or a green drive problem. The only colors you are getting are red and blue thus the purple picture. All picture tubes have red, green and blue guns to make all the colors needed for a normal picture. It will take some troubleshooting to determine whether it is a drive problem or the picture tube itself. Have a repair shop check it out for you. A 36" TV is worth a check out fee. Thanks for using Fixya. Let me know how it goes.
Nov 05, 2009 | Philips Televison & Video
Green and purple band of color
*Screen Looks 3-D
*Colors wont align
Jan 31, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Pictures are coming out green
It seems like the previous owner messed with the color effect feature on this phone. After you take the picture and its under your picture file, you can edit it. view the picture and go to options. scroll down to image editor and clikc okay. click on tools (right hand side). scroll down to color effects and click okay. now you have a menu where you can change the coloring of the picture. You may want to try the enhance green feature first and make sure its not set completely to the +5. The default settings have red, green and blue all set at zero. Hope this helps!!
KC
Oct 26, 2008 | LG Shine KE970 Cellular Phone
SAMSUNG DLP TV HLR5067W
The main board is more than likely the cause of the trouble. Time for a new TV.
Oct 29, 2017 | Samsung DLP HL-P4663W 46" Rear Projection...
Sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sony 46" RPT color problems
Hello BlueKalel,
It looks like your green CRT is malfunctioning. You should try to see if the voltages are correct on the socket of the green CRT and check the high voltage on the green CRT using a high voltage probe. Use a schematic diagram to reference these voltages to.
I am positive that the problem is the green CRT or the circuitry leading to the green CRT. Please use caution when checking these voltages.
Thank you,
Shuttle83
Sep 29, 2007 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
