After you replace the imaging drum, you should reset the imaging drum's counter. To
reset the counter, press and hold the Cancel button until all lights flash in sequence.
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Open the front cover of the printer.
Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Caution
Reset the drum counter only when you replaced the drum unit with a new one.
DRUM UNIT "spent" It can be reset if the printing quality is good To reset the drum follow the instructions below: Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover. Make sure that the Drum LED is now off. Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Brother Drum Reset Instructions The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Press the cover release button and then open the front cover of the printer.
Close the front cover. Make sure that the Drum LED is now off. Reset the drum counter only when you replaced the drum unit with a new one.
Ok, this is how I resolved it for my fax machine.
I powered down the fax, removed the new drum and reseated it.
When I powered it back on the counter reset itself as it is supposed to.
