Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
How to clone display Sony Viao laptop to ...
By ukgamer2008 on Apr 06, 2009
how to clone display Sony Viao laptop to tv using VGA lead. The TV is a samsung (model: le32a457c1dx)
Same Problem
Apr 06, 2009
-   Hi Iversh,
unfortunatly the laptop does not have HDMI only VGA so my options are limited -   Guest
Solution #1
posted on Apr 06, 2009
Not Rated)
iversh
Rank: Guru
Rating: 89%, 350 votes
If the laptop has an HDMI port and the TV has one, then just use an HDMI cable.
HDMI cable is the simplest and easiest - unlike DVI/VGA cables, an HDMI cable can carry audio as well as video.
As HDMI is a digital connection, quality of the cable isn't an issue so cheap cables are fine. You may need to change the P-Size setting on your TV, with the hdmi connection selection you should be able to cycle through 4:3, 16:9.
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
Is the Apex ld4088 a realiable set?
Answer
trying to find ot who makes vivo plasmas
Answer
My HCT HLD-42MA has no sound except for a clicking sound. The clicking sound never goes away. What... (More)
Answer
invalid format had new video card installed now says invalid format
Answer
no signal on screen with power indicator light flashing red green red green
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
