To isolate the cause of the issue, do the following: - 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert only a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: - 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: - 1. Turn off the camera. 2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Canon Digital Rebel XT / EOS
Camera will not power up, no lights no beeps nothing, the battery is fully charged and I have...
(More)
Camera will not power up, no lights no beeps nothing, the battery is fully charged and I have replaced the CMAOS battery
will not power up. was working 1 min , the next time i pulled out of case did not work, checked...
(More)
will not power up. was working 1 min , the next time i pulled out of case did not work, checked batteries, lost now
In basic mode when I push the shutter button a busy signal flashes followed by different numbers and...
(More)
In basic mode when I push the shutter button a busy signal flashes followed by different numbers and no picture is ever taken. If I turn my focus to manual focus the camera works but it does not work in auto focus.
For my Canon 350D i'm looking for cameralauncherDS.EXE which no longuer works so I cannot put my...
(More)
For my Canon 350D i'm looking for cameralauncherDS.EXE which no longuer works so I cannot put my photos from my 350D to my Vista's PC. Thanks for helping François
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads...
(More)
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads around 13. There is also a pause indicating a slower shutter speed. Any suggestions?
