Question about Toshiba A105-S4054 Notebook
Toshiba lap top
Computer will not power up. we got a digital camera card stuck in the computer. we loosened the screws on the bottom of the computer and lifted up the key board part to see if we could get to the card but this was not possible, we then put the screw back in the bottom and tried to power the computer back up but it doesnt work.
Um I had this problem with one of my SD cards as well. I found that the prongs in the slot were actually touching and one was overlaping another and my computer would not boot up correctly. It took some time and finesse but i finally got them fixed and it solved the problem.
Posted on Mar 06, 2008
  • 883 Answers
Possible that keyboard electrical connector or other connector was inadvertently disconnected. must open case and investigate further.
Posted on Sep 05, 2007
SOURCE:
How do you transfer pix on a computer/lap top? Casio Exilim ex-s5 have the plug from the box but no book to -- how to use it with the computer. Plug where in the camera? Camera plugged into the lap top?...
You can download the manual from the manufacturer's web site at
http://support.casio.com/pdf/001/EXS500_e.pdf
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Feb 06, 2011 | Casio Exilim EX-S500 Digital Camera
Cant upload photos from kodak c143 to lap top have downloaded easy share but when i conect camera to lap top nothing happens
Consider NOT connecting your camera to your computer.
Dec 29, 2010 | Kodak EasyShare C143 Digital Camera
Can not transfer pics from the camera ( coolprix L16) to laptop.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jun 05, 2010 | Nikon COOLPIX L18 Digital Camera
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
My lap top unable to recognized my finepiz digital camera when i hook up with the usb port
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 14, 2010 | Fuji FinePix Z10fd Digital Camera
I have put my cable in lap top and camera and photos dont upload
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 12, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Display problem
the best thing to do is to get the help of a qualified technician(better go to a toshiba service centre)
they will help you with this.
try removing the battery after turning off the computer and removing the power supply.reinsert the battery and turn on th notebook. it should work fine.
else contact the technician.
Dec 03, 2008 | Toshiba P25-S676 Notebook
Memory Card for digital Camera
After inserting the card, go to my computer and see if it shows the memory card inserted. If so, click it and then when it opens, click copy to location and you choose the location, easiest, my documents and then my pictures.
Dec 26, 2007 | Cameras
Lap top computer power problem
Screws, if overtightened or replaced with the incorrect size (i.e., too long a screw), can somtimes cause a board to short. Try taking the screws out completely and then see what happens. It's also possible your laptop may have a bad power supply as a result of the case having been taken apart or put together incompletely. If the first step doesn't work have it diagnosed by a competent repair person . Also, you may consider trying one of eBay's "laptop power" repair services postings. Some offer to replace your power supply fitting (rear plug) for about $50 plus shipping.
Sep 10, 2007 | Toshiba Satellite M35X-S111 Notebook
Toshiba A105-S4054 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
