Question about Microsoft Windows XP Professional for PC
Unmountable boot volume error
Please help!! have lost xp cd
  • chawk Jan 08, 2008
    Sony vaio laptop - Xp pro, will not boot all the way. Right after the winxp splash sceen disappears I get a blue screen w/ "Unmountable boot volume and reboots over and over. This is the third time. The first time, after much troubleshooting, the Toshiba hard drive had to be replaced. The Second time the "chkdsk /p/r" worked for about two months, but now it's doing it again chkdsk found. I searched online using "sony laptop/toshiba hard drive" in the search engines and found that I'm not the only one having this problem. I know that some companies have firmware that fix repeated issue, but I can't seem to find one on sony's site. Can anyone help me please.
  • shawnice Jun 27, 2008
    I have a Dell Inspron 6000 notebook and when it starts up with a black screen white writing it says UNMOUNTABLE_BOOT_VOLUME
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 255 Answers
You can probably get it from whomever you bought the computer at...
Posted on Jul 13, 2010
    President:
  • 2,961 Answers
If you know any body who has a copy of xp then you can use their cd, but use your product key number that is on a sticker on the underside of your laptop, but if you had xp home dont use xp pro cd as it wont work when you input the product key. This is quite legal as you purchase the XP licence number and not the cdrom so see if you can lend one from somebody.
Posted on Sep 04, 2007
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
Getting "unmountable boot volume" error
Windows is totally corrupted - you will have to reinstall it. For that you will need an external CD unit and the recovery disk that came with the Mini. If you don't have it then you can either buy it from HP or borrow a similar XP install disk from a friend and use it and your key.
Mar 13, 2011 | HP Mini 1000 Netbook
Hi i have an acer aspire 3690 and cannot boot the pc as it says unmountable boot volume. i dont have the recovery cd or bios password as bought from someone i used to know in the uk and im no longer living...
Hello
Thank you for using
FixYa for your problem
If you receive the “unmountable boot volume” error and have an installation disk, you still have a chance to save your system.
1. Insert your XP installation disk into an optical drive and boot up your computer.
2. When you see a welcome screen, hit the R key on your keyboard. This will enter you into recovery mode with a DOS prompt.
3. Now type chkdsk /p and hit Enter. This will launch a utility which will check for errors on your hard drive.
4. After the process is done, type fixboot and hit Enter to repair any damaged boot files which may have become corrupted. When asked to say yes or no, type the Y key on your keyboard.
5. Type exit and press the Enter key to reboot your computer.
If all went well, you should now be able to boot back into Windows without a problem!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Acer Aspire 3690-2196 Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
I have the same issue and my aspire is idle for last 4 years...
Jan 12, 2009 | HP Compaq nx7010 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
Averatec 3280 unmountable boot volume
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Nov 22, 2008 | Averatec 3200 Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Microsoft Windows XP Professional for PC Logo
1,160 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
