Question about Panasonic PV-GS2 Mini DV Digital Camcorder
Tape wont eject, play, or rewind. It tries, but soon the message to push reset comes up. No help. Camera works ok otherwise.
  • 73 Answers
Put the camera to your ear , power it up and listen ! if it sounds . . . jerky ? your tape is stuck to the heads ( not easy to get out , cassette may be toast and - time is money ) ; if you hear whirring sounds ? before shuts down your cassette housing may be bent ( will need disassembly etc . but not usually expensive ) because - if it is a loading problem , it will usually eject ;
Posted on Sep 05, 2007
  • rafael quinones lopez
    rafael quinones lopez Sep 05, 2007
    sometimes , if you hold the eject button down
    the tape will eject ! if tape is stuck to heads
    ( tape will still be inside camera ) remove the
    battery - if tape is valuable , take it to
    a good repair shop and they may be able to
    save . . . the tape ;
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Please re-operate after pushing reset button
Just push the "reset" button and try again. The reset button is next to the EJECT button. You will need something small to push it in.
Jul 08, 2009 | Panasonic NV-DS27B Mini DV Digital...
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Feb 03, 2009 | RCA VR639HF VHS VCR
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
"Push the reset switch"
I had the same problem with the 'push the rest button' on the display after the tape mechanism jammed up against the tape compartment cover. I figured there was probably a mechanical error, possibly a switch. I dissassembled the camcorder and found the tape compartment cover switch was sticking. Here's how to fix it with some photos to illustrate:
1. Open the tape compartment door and remove the screws in the small plastic cover (fig. 1). Remember to look a which screw came from each hole as they are all different.
2. Remove the plastic part from above the tape mechanism (fig. 2)
3. Remove the screw above the front grip belt mount (fig. 3)
4. Remove the screw above the mic (fig. 4)
5. Remove the battery and take out the screw at the top left under the viewfinder (fig. 5)
6. Take out the screws under the LCD monitor (fig. 6)
7. Remove the two screws from the front underside of the camera body (fig. 7)
8. Now you can slide the front of the camera, together with the curved aluminium top section away from the main body of the camera (fig. 8)
9. It is possible to reach the switch with the front moved forward slightly, but it is possible to take the front off entirely by removing the wiring ribbon with the green tab (fig. 9)
10. Clean the brown switch at the bottom left of the exposed camera front with a soft brush/air (fig. 10 )
11. Reassembly is the reverse of the above procedure.
Hopefully this will mean no more frustration with the 'press reset button' screen.steviedeee.jpgsteviedeee_0.jpgsteviedeee_1.jpgsteviedeee_2.jpgsteviedeee_3.jpgsteviedeee_4.jpgsteviedeee_5.jpgsteviedeee_6.jpgsteviedeee_7.jpgsteviedeee_8.jpg
Jan 21, 2007 | Panasonic NV-GS15 Mini DV Digital...
Wont accept DV tape..
i have the same problem, but i did nothing wrong to prompt this problem at all. It was sitting on my desk, it worked, then it didn't. go here....
Dec 30, 2006 | Canon ZR200 Mini DV Digital Camcorder
Tape will not eject, and reset button does NOTHING!
I am having the exact sam problem on my PV-GS14. Have you been able to resolve the problem? If you have, how were you able to get the tape out? Thanks
Nov 13, 2006 | Panasonic Palmcorder PV-GS14 Mini DV...
Panasonic PV-GS2 Mini DV Digital Camcorder Logo
254 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
