Question about Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop
Installing RAM Hi, I have an HP media center PC, the M1000 series, I need to install more RAM, but I can't see where it goes.
    Genius:
  • 1,226 Answers
Yup,
YOu need to open the casing and then remove the memory ...want to see memory just search in google..
after removing u can bring the memory to the vendor to have same spec or read the information about your computer ..see..your manual.
melnavz
Posted on Jan 30, 2009
  • 20 Answers
I was not able to find specific information for that computer but replacing memory on any desktop computer is usually pretty straight forward. You would unplug from power, remove the screws for the cover, and locate the slots that hold the memory chips and add the memory. It might be a case that all of your memory slots are full and you'll need to remove some of the memory first. You could replace them with larger capacity chips. HP lists generic memory information at http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03886&lc=en&cc=us&dlc=en&product=426931&lang=en Good luck
Posted on Sep 05, 2007
How do i use the mmc/sd port
Hi !
First, you have to make sure that you have installed the proper drivers for your mmc/sd port.
http://support.hp.com/us-en/product/HP-Media-Center-m7000-Desktop-PC-series/1847154/model/3185130/drivers
Restart after installing. After that, just insert the mmc into the slot and you should see it on "My Computer" or press Win+E.
May 22, 2014 | HP Pavilion m7570n (EX331AA) PC Desktop
Installed Window 7 64bit Ultimate on my HP Media Center M7250n PC desktop. Did express install. Audio problem fixed by reinstalling RealTek driver. Hauppauge sound driver was installed by express...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Nov 14, 2010 | HP Media Center m7250n (ED842AA) PC...
For hp multi media center. i'm trying to recover original system using discs. What is procedure for this and do discs go in, in a certain order other than 1 to 7
They should be self installing. Just put the first disc in and it will tell you what disc to put in next. They usually go in order.
Jan 04, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
My media center does not record anymore. What is wrong
you just hav to install a new media center. by installing this ., you will not have to face these problems
Sep 15, 2009 | HP Pavilion Media Center a1330n - AMD...
Installation instructions for 6100 to laptop required
Here is the Setup Sheet:
Lexmark 6100 Series Setup
And...the User Guide:
6100 Series User Guide
Here is the link to download drivers if needed:
6100 Support
Click on the Downloads tab. Select the correct one for your Opeating System.
Sep 08, 2009 | HP Pavilion Media Center a1330n - AMD...
Hp media center power
hi friends, unpluug the power chord from the wall jack after that press and hold the power button in the front for about 15 seconds, connect the chord back in and try it. if it does the same then look at the rear side of the cpu box (where the power chord goes in and look for a small fan inside the power supply box, it has to be spinning). if not then the power supply (smps) has goen bad. now if the fan is sipnning try disconnecting all the extra periferals eg printer and stuff, still nogo then try opening the cpu box (reffer owners manual). take the RAM out and try to power up the system, if it starts beeping like beep ...beep... peeeep... then turn it off put the ram sticks back in and it should work fine...
NB:-for the owners manual check this out: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&product=470506&lc=en&jumpid=reg_R1002_USEN
Jul 11, 2008 | HP Media Center m7060n PC Desktop
Hi, I just got a new pc HP Media Center M8430F, and I am not able to record stream audio or internet radio
I have an HP with Media Center as well.
Generally you need a software program that specifically records streaming audio and or video. A freeware program I use is OpD2d. Google it and install. Very simple to use.
Apr 16, 2008 | HP Media Center m7250n (ED842AA) PC...
Cant able to open windows media center and quick play from the remote control
Hello!
the ultimate solution of your problem is to reinstall the windows operating system of your system. I am sure this will resolve the issues.
After install installing the OS, you should install all the drivers.
May this help!
best regards, melnavz
Mar 02, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop Logo
252 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
