Question about Epson Printers & Copiers
SOURCE: epson DX4000 printer
my epson settings were recently changed by someone in order to take a passport photo copy and now all I get is about 1 quarter of the A4 that copies + all the tech support is in German!
Posted on May 08, 2008
  • 85 Answers
SOURCE: ink not empty
Hi Download this FREE Epson Chip Re-setting and cleaning
programme and reset the chip to FULL
Click here to download
Once installed... To launch programme on WinXP connect your printer !
USE "RIGHT HAND MOUSE BUTTON" to Click on the "SSC Service Utility ICON" found on bottom right of your monitor. (WIN XP)
you will see all the possible options.. your printer/s should be recognised automatically and display all
options available.
Epson Stylus Printers supported by SSC Service Utility Ver 3.80:
Main features.
SSC Service Utility allows you to do many amazing things with Your Epson printer :
1) Work directly with CSIC on Epson Stylus cartridges.
2) Freeze internal ink counters.
3) Reset internal ink counters even with empty cartridges.
4) Separate cleaning of color and black print head for all Epson inkjet printers, also has a powerful cleaning mode.
5) Hot swapping of cartridges supported.
6) Resetting of protection counter (even if it is full).
7) More then 60 different Epson printers supported
This allows many people with high printing demands to save money (as the program works with both black and color cartridges).
Up to date this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Supported printer models (16.10.2006)
Epson Stylus Color 400
Epson Stylus Color 440
Epson Stylus Color 480 LPT
Epson Stylus Color 480SXU / 580
Epson Stylus Color 600
Epson Stylus Color 640
Epson Stylus Color 660
Epson Stylus Color 670
Epson Stylus Color 680 / 777
Epson Stylus Color 740
Epson Stylus Color 760
Epson Stylus Color 800 / 850
Epson Stylus Color 860
Epson Stylus Color 880
Epson Stylus Color 900 / EM-900C
Epson Stylus Color 980
Epson Stylus Color 1160
Epson Stylus Color 1520
Epson Stylus Color 3000
Epson Stylus C20 / C40 / CL-750
Epson Stylus C41 / C42 / C43 / C44 / C45 / C46 / C47 / C48 **
Epson Stylus C50
Epson Stylus C60
Epson Stylus C61 / C62 **
Epson Stylus C63 / C64 **
Epson Stylus C65 / C66 and PE **
Epson Stylus C67 / C68 / D68 and PE **
Epson Stylus C70 **
Epson Stylus C80 **
Epson Stylus C82 **
Epson Stylus C83 / C84 **
Epson Stylus C85 / C86 and PE **
Epson Stylus C87 / C88 / D88 and PE **
Epson Stylus Photo RX420 / RX425 / RX430 **
Epson Stylus Photo RX500 / RX510**
Epson Stylus Photo RX520 **
Epson Stylus Photo RX600 / RX610 **
Epson Stylus Photo RX620 **
Epson Stylus Photo RX700 **
Epson Stylus CX3100 / CX3200 **
Epson Stylus CX3500 / CX3600 / CX3650 **
Epson Stylus CX3700 **
Epson Stylus CX3800 / CX3810 / DX3800 **
Epson Stylus CX4500 **
Epson Stylus CX4600 **
Epson Stylus CX4100 / CX4200 **
Epson Stylus CX4700 / CX4800 **
Epson Stylus DX4200 / DX4800 **
Epson Stylus CX5100 / CX5200 **
Epson Stylus CX5300 / CX5400 **
Epson Stylus CX6400 / CX6600 **
Epson Stylus CX6300 / CX6500 **
Epson Stylus CX7800 **
Epson PictureMate
Epson Stylus Photo
Epson Stylus Photo EX
Epson Stylus Photo 700 / IP-100
Epson Stylus Photo 750 / PM-770C
Epson Stylus Photo 780 / 790 / PM-780C
Epson Stylus Photo 810 / 820
Epson Stylus Photo 820 **
Epson Stylus Photo 825 / 915
Epson Stylus Photo 830 / 830U **
Epson Stylus Photo 870 / PM-875DC
Epson Stylus Photo R200 / R210 **
Epson Stylus Photo R220 / R230 **
Epson Stylus Photo R300 / R310 **
Epson Stylus Photo R320 **
Epson Stylus Photo R800 / PX-G900 **
Epson Stylus Photo R1800 **
Epson Stylus Photo R2400 **
Epson Stylus Photo 890
Epson Stylus Photo PM-890C
Epson Stylus Photo PM-A700 **
Epson Stylus Photo PM-G720 **
Epson Stylus Photo PM-970C **
Epson Stylus Photo 895/ 785EPX
Epson Stylus Photo 900 **
Epson Stylus Photo 925 / 935 **
Epson Stylus Photo 950 / 960 / PM-950C **
Epson Stylus Photo 1200 / PM-3000C
Epson Stylus Photo 1270 / PM-3300C
Epson Stylus Photo 1280 / PM-3500C
Epson Stylus Photo 1290
Epson Stylus Photo 2000P
Epson Stylus Photo 2100 **
Epson Stylus Photo 2200 / PM-4000EPX **
Epson Stylus Pro 5000 / PM-5000C
** - NOTE! It is impossible to reset ink counters by software methods on these printers.
Use "ink freezer" function to maintain current ink level and "hot swap" to use refilled old cartridges.
Hope you like the FREE shareware programme
Click here to download.
Good Luck!
Tinteiros (Ebay)
Posted on May 30, 2008
  • 353 Answers
SOURCE: epson c88 prints horizontal lines
It looks like storm_christ has lost interest in this problem, so we may call it "solved by poster".
Posted on May 06, 2009
  • 26 Answers
SOURCE: epson stylus dx4000 printing blank pages . how do
replace cartriges, clean printers heads from utility menu
Posted on Oct 25, 2009
  • 1011 Answers
SOURCE: my epson dx4000 Cannot recognise ink
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Posted on Dec 08, 2009
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
0 characters
1 Points
Have changed all cartridges on epson nx400. test shows 3 ink cartridges printing, except for the black ink. have run clean head utility, ink has charged. downloaded and installed printer driver. Found an...
The ink reservoir doesnt have to be completely empty to fail. Replace the cartridges. Some of the jets or all of them may be clogged especially if you have not used your printer in a while. If there are cleaning instructions in the manual clean the jets and then try to print from the printer's self test
Mar 09, 2011 | Epson Stylus NX400 InkJet Printer
Epson stylus dx4000 printing blank pages . how do
Oct 25, 2009 | Printers & Copiers
Bad printing after changing 2 inks also clicking noise not before
shouldn't be the ink. I assume you have an epson as in the picture. my ink refill kit mentions that "epson intellidge chipped cartridges" require an "ink level resetter" to complete the kit. So if you have these cartridges even once refilled the chip tells the printer the cartridge is still empty so you'll need to reset the chip with the ink level resetter.
Aug 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
I just changed the black ink cartridge (Epson) but
geh mas nek iso kowe tuku printer maneh ..opo ra duwe duit go tuku maneh,,,piye to...jere sugh.....nek ora duwe duit ngepet wae to
Aug 11, 2009 | Epson Stylus C86 InkJet Printer
My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Apr 28, 2009 | Epson Stylus NX400 InkJet Printer
Epson RX420 new black ink cartridges displaying empty
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Epson RX620 All-In-One InkJet Photo...
Won't print after changing ink cartrages
After you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks,your printer will require service.
Contact an Epson technical support representative at (562) 276-4382 for further assistance.
Nov 24, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Changed the black ink cartridge but can't print just black
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Sep 01, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Won't print unless all ink cartridges have ink.
Try changing it in the properties section under device settings
or go to color management if you have it and change the setting to black only,.
Aug 07, 2008 | Epson Stylus C84 InkJet Printer
Epson DX4000 printer
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Feb 06, 2008 | Printers & Copiers
Printers & Copiers Logo
191 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
