Question about Epson Stylus CX3810 All-In-One InkJet Printer
Ink light on
I replaced the black ink yet the light stays on. Nothing will send to printer. I can't even do a test page. Do I have to replace all the colored ink? Can I tell which one is empty? I always use Epson refills and print often. I can't copy either. Any suggestions?
  • fortierholt Jan 22, 2008
    I am encountering the exact same problem and can't for the life of me get it to print. I need to get a resume in so I am desperate. Any help would be appreciated.
  • 26 Answers
You must verify all lefvels of yopur ink cartrages some of the others maybe low
Posted on Mar 08, 2008
SOURCE:
Ink printing problem
Sounds like you already know the answer to that question ;(
Printers today are generally disposable due to the high cost of replacement parts and the cheapness of a new unit. I had a similar problem and replacement was the cheapest alternative.
Oct 05, 2015 | Canon MX340 AllInOne InkJet Printer
Heavy black stripe on back side of every printed page
This is probably due to miss alignment, there is an option of test page which will be scanned to allign the cartridge, if ur's a all in one printer. This test page is printed at the first time and scanned instantly for first time operation.
Thankyou
Mar 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My HP C4780 PRINTER WILL PRINT A TEST PAGE BUT NOTHING ELSE. How do I get it to print?
Check the settings in Windows Print Manager.
Make sure that the paper quality matches what is in the printer. If set to glossy, minimal ink is deposited on the page. Also, check the print quality - draft quality provides a minimal amount of ink as well.
Jan 17, 2015 | HP PS C4780 All in One InkJet Printer
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
New ink; nothing on page
Might be the line going to your ink is clog or there is a dry ink that causing to black the pressure in order the ink to come out.
Jul 23, 2009 | Dell A940 All-In-One InkJet Printer
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Feb 11, 2009 | Epson Stylus 830U InkJet Photo Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
Jun 11, 2008 | Office Equipment & Supplies
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
