HP 4si
posted by joeyschmoe on Sep 04, 2007
Hp 4si laser jet prints the page with heavy dark toning on both edges right & left . Lately toning dark over the entire face of the page , makes otherwise good printing hard to read . The edge toning is heavy in about 1 inch from each side . Any help ?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 04, 2007
Thanks for Trying (70)
Printerguy
Rank:Wiz Wiz
Rating: 89%, 68 votes
When I've worked on printers with this problem in the past it usually comes from the high voltage power supply going bad. There is also a low voltage power supply that runs everything except the actual printing so your printer will still operate without any errors but the print quality will go bad. The high voltage power supply is located under the bottom of the printer and it's too hard to replace. I can't advertise for any place on this site, but if you type in the part that you need into a search engine and look for parts on everyone's favorite bidding web site you should find the parts you need. Good luck.
Rating Locked! (?) joeyschmoe has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HP 4si:
I don't want to Accept this solution
Can you Help with these Printers problems?
HP LaserJet 4si Printer
Even with new pickup rollers. Have three, all have...
The laser printer will not print the last 3 inches of text...
i have a 4si printer . when i select thre paper from lower...
I solved the jamming problem and now when I run a job...
Printer does not come on when energized. When the switch...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Printers
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
(972) 907-9771
Genicom, Decision Data, Printronix,...
Sinca
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
