Question about Samsung SGH-X830 Cellular Phone
Remove front cover
Hi , i have broken the front screen (lens) and have been trying to remove it with no success, anyone know how? thanks simon
  • brabus Oct 14, 2008
    changing the case
  • Anonymous Dec 21, 2008
    I want to change the coner of this mobile
    Brigadier General:
  • 7,752 Answers
You should take the phone to a mobile center and have them remove it for you.
Posted on Aug 31, 2008
SOURCE:
Hi there, i have a problem with my GZ-MG21u. error in HDD and always says"please remove lens cover".i tried to switch in sd card but still black screen appears.please help me to resolve so that i could...
On some cameras the lens cover engages a small censer that gives the message remove lens cap. fit and remove the lens cover a few time this may work , if not the censer may be at fault.
Dec 20, 2014 | Video Cameras
I started taking pics on my daughter's birthday function.. at the end of the function, my friend tried to take the camera from me but unforturnately it fell down. But we continued take pics and but after...
Try repeatly turning on and off the unit by removing the battery each time the lens error screen pops up...that worked for me this summer when mine S210 got jammed with a sand particle. The next level is to get access to the front cover. That requires more knowledgethan I'm currently aware of as I've only removed the back cover and the LCD retainer plate. Tomorrow I'm going after the front cover and I'll let you know if I'm successful. The entire camera seems to be accessible with a small phillips head screwdriver and a lot of patience. Taking apart an S210 requires great peace of mind...don't go in until you're in a good space...
Sep 27, 2010 | Nikon Coolpix S210 Digital Camera
Cleaning webs from inside screen
There are two ways to do this---the hard way which is to remove the entire front screen OR
What I do is (with the set unplugged) remove the back cover of the set; you should see the three large black lens.
Most of these sets there will be enough room to get a swiffer duster up inside to gently catch and remove all the spider webs. If there is not enough room let me know and I will tell you how to remove the front screen.
Also---if you can see those large black lens---clean the dust off of them with a lens cloth or paper towel with glass cleaner sprayed on the towel.
If you can reach the webs from the back do not exert pressure when you wipe the inside of the screens---easy to scratch them.
If you have questions let me know BEFORE you attempt this.
If this helped or told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Toshiba 57H82 57" Rear Projection...
Blackberry 8700g screen lens replacement directions needed
Hi.....don't know if you have already resolved this problem, but if not, you can view this video on you tube which shows you exactly how to do it. This doesn't say 8330 but still applies same as the others.  BlackBerry 8300 8310 8320 lens replacement proceedure
Apr 19, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Lense won't retract on Canon Powershot SD630
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. You're also more likely to be successful trying these than going inside the camera:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Finally, if you absolutely must open the camera, here's a couple guides to replacing the camera's LCD that may help:
http://cannonlcdrepair.blogspot.com/
http://digitalcamerarepair.googlepages.com/sd600
Jan 04, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Spring visible through the lens
Defective Lens Block.
Needs to be replaced.
Aug 15, 2008 | Pentax Optio 555 Digital Camera
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
BE-300-How do I open it to remove the touch screen?
As I remember it has some plastic bulges that fit into some indentations. Some gentle prying toward the bottom should show you some success. To get the things that hold it together apart you need to press in on one part and lift up on the other, but don't remember which. If you don't get it email me and I will go dig my old one out of the junk box and see which is which. It, by the way has a good screen/touchscreen I think, the light circuit got busted on it and I can't get parts.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
Samsung SGH-X830 Cellular Phone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
