Please do the following to fix the problem:
1. Power cut: First, unplug the washing machine and wait a few minutes.
Then plug it back in and try starting the app again.
2. Resetting the washing machine: If turning off the power alone does not solve the problem, you may need to reset the machine.
To do this, press and hold the Quick Start button for 5 seconds to reset.
Then try starting the program again.
3. Checking the water level: Make sure that the water level in the washing machine is correct and that the water supply line is connected correctly.
If the water level is low, it may cause "Err 105" error.
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
To change the keyboard,
Turn key to program
4 SUBTOTAL
082
Now press the position where you want the X multiply button
034
Now press the position where you want ERR CORR button
SUBTOTAL
as for the amount limitation, try it on the item that you set as 0 last time (3 SUBTOTAL 0 item SUBTOTAL). I need to know if it affects all items or whether any items you set as 0 above will work at less than $1.00. I don't think it has anything to do with training mode. Probably has a limit set from previous owner
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets 1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems. 1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open. 2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct. 3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart. 4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door. 5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart. 7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem. 15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine. 15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
