Compaq Evo N800v Notebook Logo
Posted on Apr 06, 2009
About my Compaq Evo N800v Notebook PC laptop screen problem
My laptop is not working in the proper manner.Because for the screen the belt is may be some loose contact.some times the screen is shaking at the time of booting and immediately hanged.Then system is not working.Some times if we press upon the screen then it will work in good manner.If we remove the pressing hand,immediately the screen shakes and hanged the contents immediately.I think some loose contact/any vga card /drivers problem?.Please inform clearly to my e-mail.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
339
Points
Compaq notebook evo n1020v won't power up. Battery charger is brand new.
Remove the main battery, now try power on, if okay the battery needs to be replaced. Sub out ram one at a time to see if you can start it.
I want vga aput compaq evo n800v?
You can download the drivers from the Compaq/HPWEB support/download page. Make sure you select your model laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
2helpful
2answers
How do i turn off tapping on a compaq evo n800v
Assuming Vista
  1. Start button
  2. control panel
  3. mouse settings
  4. Advanced tab
  5. Properties
  6. Tapping option.
  7. Turn it off.
1720-SMART hard drive detects failure (failing attr : 0&)
Please ensure you backup your Hard drive and get a new hard drive ready for installation. Usually if you get a SMART error, you hard drive is about to fail or showing signs of failure.
1helpful
Kindly assist me with -video controller driver- for my compaq Evo N800V, its missing here
Go here to HP support, download and install the graphics drivers for the Evo, the drivers are ATI >>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=uk&prodNameId=97150&prodTypeId=321957&prodSeriesId=96321&swLang=8&taskId=135&swEnvOID=1093
Good luck.
My CDR Drive is not working
your problem is very clear... your cd-rom is corrupted.. install new windows... im very very very sure of your problem... NOTE-do this only if your cd drive is NOT displayed in my computer.. do this....
please vote for me...im sure this will solve your problem...
N800v harddrive blew out
It depends upon your needs, the larger the hard drive to higher the cost and the maximun size you can install depends upon the BIOS. The smallest hard drive that is readily available is about 100Gb.
Compaq evo n800v saying non system disc or disc error
You need to check in the BIOS to see if the hard drive is being detected. Other than that, do you have like a flash disk or a media card attached to it when booting up?
My Scroll botton will not work on my Evo N800v
You dont need to use the scroll on the touchpad just use the up and down arrows on the right hand side of your touchpad, you will find this easier to use and operate too
I want to open my hardrive in the model EVO N800V COMPAQ to replace it..kindly help..
Looks like it's just a notebook IDE drive. On the bottom of the laptop, there should be some symbols that look like hdd platters in a vertical line. Unscrew the screws next to these symbols and pop that cover. Remove hdd, take old hdd out of the metal cradle it's in and put the new on in there. Then screw back together.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
