Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Stylus 710 Memory card error
When the memory card (fugifilm 512 high performance type-H xD )is installed and I try to format it says memory card error! I have tried it lots of times and it does the same, please help!
  • nixluck Dec 27, 2007
    I bought a SanDisk XD 1GB memory card having tried a fuji card and took it to jessops who tried formatting it on another olympus camera (which worked) but when it was put into my camera, card error still appeared. Plesae help!
  • Marieah May 02, 2008
    My Olympus D-535 worked (and still works) just fine on its internal memory. But when I inserted the 2 gig Fuji xd card I bought for it, it displays the presence of the card and tells me how many shots I have left. Everything is normal until I take a picture at the highest quality shoots the pic, then instead of displaying it, it completely freezes and gives me a black screen. I can only turn it off by opening the battery compartment. It works fine on the lower settings. This really irks me as I bought it to take high quality pics for hi res textures for 3d models.
  • 49 Answers
Try formatting on another fuji/olympus or on a computer, and then again in your camera. this should work no problem. Usually this is just a file system error. In the odd case it is a card or camera error but not likely at all.
Posted on Sep 16, 2007
A few things here, first have you just downloaded your pictures to your computer? If so then remove the memory card from the camera and make sure the little "lock" switch on the side of the upper left corner is in the unlock position. Unlock position is with this slide type switch pushed towards the top or the gold contacts. The you insert the XD card back into the slot making sure not to move teh little switch. The close the compartment turn on the camera and go directly to your menu and format the card. If this was a new card then it needs to be formatted, if this card has just had pictures downloaded to the computer then it needs formatting. There are a number of reasons for card error messages but most if not all can be solved by formatting the card
Dec 25, 2010 | Olympus Stylus 710 Digital Camera
Format xd card error I bought new Fugifilm xD-Picture card, 1 GB, and putit in camera. Brought up format screen and attempted to format. All I got was "card error!". I thought the problem might be the...
Try formatting the card on your pc, connect the card to a card reader, open my computer find the card, right click format, try standard fat first and format. if that doesn't work try Fat 32.
Jul 16, 2008 | Olympus Camedia C-350 Digital Camera
What is the maximum memory for Olympus Stylus 710
The indicade cards to your cam are:
xD-Picture Card (16, 32, 64, 128, 256, 512MB or 1GB)
The maximum value to your cam is 1Gb.
These information are from Olympus manufacturer.
If you need more details about your camera, click here:
Sep 24, 2009 | Olympus Stylus 710 Digital Camera
Memory error
Have you formatted the card in the camera before trying to use it? (download any pictures still on the card using a card reader if necessary).
Aug 14, 2009 | Olympus Stylus 820 Digital Camera
Card error
It probably can't use the high speed card.
Jul 25, 2009 | Cameras
Fugifilm finepix camera won't read memory card
Hi there.
Pop the card in the camera, then use the camera's menu to format the card, if it formats you should be good to go.
Good luck and thanks for using Fixya!!!!
Feb 11, 2009 | Fujitsu Cameras
Card Error
Try formatting it in the camera first.
But a couple of cards is a good insurance any way
Nov 08, 2008 | Olympus Stylus 710 Digital Camera
Xd cards on my olympus (stylus 710) camera to computer
You will want to format the memory card in the camera. This will permanently remove all of the data from the card. To do this go to Menu - right arrow to Setup - press Ok - select Format - right arrow - select Yes and then press Ok. The camera will indicate Busy as it is performing the operation. When done the camera should read No picture. You will then be able to start taking brand new images again.
Jun 24, 2008 | Olympus Stylus 710 Digital Camera
Has your camera always done this? Or is this a recent problem.
Also, have you changed your memory card, and that has caused your error?
Some times if you use a higher capacity memory card than the camera can use (especially with the xD card format) you will encounter very wierd errors, as the camera is trying to read or save to the card.
One thing to check is the memory card type. Olympus uses the xD card, BUT in the last couple years they have changed the format, from an xD card to an xD card type "M". The type M has a different file structure, and older cameras, and ones that can't support the "M" format might give odd errors.
I checked Olympus' website and I did NOT find any drivers for your camera, which is odd. Try uninstalling and reinstalling your software, and also check your memory card. If you have an extra around, try using it (I wouldn't recommend go buying a new one as many places do NOT let you return memory cards).
Let me know if this helps!
Nov 18, 2007 | Olympus FE-230 Digital Camera
Memory Problem
have you tried formatting the card first within the camera, as it may be corrupt, or try it in a card reader and format that way.
May 18, 2007 | Fuji FinePix A330 Digital Camera
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
51 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
