Question about Danby DKC645BLS Compact Beverage Cooler
Major leaking with kegerator (DKC645BLS)
I've only had the keg a month, so before I blame the keg, I'd like to find out if I'm doing something wrong. I'm on my second keg, and both of them have significant dripping occuring in the front and back. I open the keg, and there's barely any evidence of where it's coming from. There is a tiny bit of foam near the interior tapper, so I kept thinging that maybe the little washer inside the nut that attaches beer line to tapper wasn't on right. I've tightened it as much as you can by hand, and that only made it worse. My carpet is now destoyred, so I bought a drip tray that is normally used for a laundry machine. Every two days or so, I have to towel up the beer or risk it smelling like delicious yeast in my house. This can't be normal, so if anyone has any ideas, please assist.
  • scott46 Nov 27, 2008
    I am having the same exact problem. I did my first cleaning and disconnected the inlet but did not see any washer or oring. That's probably the problem. I don't understand why this f'ing keg cooler didn't come with an oring or washer.
  • 99 Answers
Using a tray is not the answer. Your tapper is not propperly lineing up with your kegs inlet. Try replacing your tappers washer and o ring, if this does not work you need to replace the tapper itself. It is most likely bent and not propperly lineing up.
Posted on Jan 26, 2008
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Should the fawcett parts be leaking?
replace the rubber seal gasket in the hose connector
Apr 14, 2015 | Beverage-Air Kegerator - Beer Keg Cooler...
Bought a used danby DKC645BLS kegerator it is missing the co2 tank bracket that mounts on the back of the kegerator, where can I find one. Also the psi is set at 10 on the co2 tank and the beer comes out...
mark pasieka has an inventory of refridgeration, kegerator and bar related parts (as well as everything else)... he has this bracket in his warehouse right now... at least one... he also has tanks of CO2, oxygen acetalyne anything you may need...
Oct 06, 2010 | Danby DKC646BLS Full Size / Pony Beer Keg...
Where do I get replacement parts for a Danby Kegerator Model DKC645BLS ?
I have Danby keg cooler touch pads in stock, the touch pads are the most common failing part on the coolers, I also have access to many more parts as well as technical assistance, please ask for Erin (509) 928-7176
Feb 04, 2010 | Danby DKC645BLS Compact Beverage Cooler
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have an older beer cooler. the fan costantly runs but the refrigeration part of the beer cooler doesn't keep the keg cold? ? ? It's refrigerate is r12 cooled. Do you think I could just re charge the...
You would need to be a certified refrigeration technician to even buy R-12, since it is a CRC refrigerant. The kegerator probably doesn't have service ports so you would either have to braze a low-side port in or use a piercing valve, and fix wherever the refrigerant leaked out from. Basically, by the time you pay a refrigeration tech to do all this, it isn't worth it and you would be better off buying a new one
Jun 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Danby DKC645BLS Kegerator
i had the same problem with mine. i fixed it by removing the guts from the faucet and reversing the seal on the closing part. the seal was on backwards, flipped it and no more leak.
Jun 14, 2008 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
304 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
