Question about Panasonic NV-DS60 Mini DV Digital Camcorder
There is a red on and off icon on the sceen
The power stays on for just 5 secons ond it goes off
  • 33 Answers
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Posted on Feb 21, 2008
My Sony tv won't power on its goes on then stays blinking on standby 14 blinks on red
Try unpluging the tv for several minutes and then plug it back in and turn it on and see if that helps
May 22, 2015 | Sony Televison & Video
Monitor goes blank after 5 secons
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 10, 2010 | Computers & Internet
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
Pushing on power button three green lights come on for one secone
click here you would find the details for led codes. you may select any laptop. codes remain the same.
Sep 24, 2009 | Dell Latitude D600 Notebook
Wont post led 3 flashes
if its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Sep 07, 2009 | AOpen AX4SPB-UN (91.8AT10.013) Motherboard
My dell (monitor) it turns on few secons but the image goes off,
First you'll have to power off the system.
Please power on the system and as soon as you see the Dell logo please tap the F2 button 3 - 4 times.
The computer will go to the system setup. Check if the screen goes blank here.
If the screen stays on then try this.
1. Please power off the system.
2. Please power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll reach the Windows Advanced Boot Options Menu on the screen.
3.Select Safe mode with Networking.
4. Select Administrator at the log in screen.
5. Warning dialog box with the message Windows is running in safe mode. appears. Click the Yes button.
6. The desktop appears with the words Safe Mode appearing in all four corners.
7. Uninstall the video drivers and restart the computer.
8. Resintall the video drivers.
Rate if useful.
Aug 19, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Red Line on the left side of the screen
This is a serious problem, you have to call SS right away since it is in warrantee. They need to check whether the panel is defective.
Aug 13, 2009 | Samsung PN42A450 Plasma TV
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Powers on 5 sec then powers off
if it goes off even with no sound, system is put on stndby protection mode. something wrong with your output section. busted power output xtors of IC.
Mar 17, 2008 | Audio Players & Recorders
Pic taken stays on lcd screen too long
In the auto review section (under the setup menu) change from 5 seconds to 1 second.
Dec 26, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
95 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
