Question about Danby DKC645BLS Compact Beverage Cooler
Temperature light control (kegerator DKC645BLS)
First off, I'd like to know if anyone else has to attempt 4 or 5 times of pressing the gauges in order to get them to work? As well, once I do get it to work, it now will not allow me to go below 36 degrees. Even with that occuring, the kegerator doesn't always stay at the setting I have it on. I keep assuming there is a crack somewhere, but have yet to find one. It is constanly fluxuating between 34 and 38 degrees. My girl is a month old, so this can't be from wear and tear. Anyone that knows anything, your help is greatly appreciated.
  • dripdrip Sep 04, 2007
    That makes sense, but doesn't explain why the temperature gauge won't even allow me to attempt to set it below 36 degrees if I so choose.
Here is a quick and easy fix. Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Posted on Oct 05, 2007
Had a very similar problem but mine was only two days old. At first the controls worked. Then I could get them to raise or lower the temp. It seemed to cycle through temps ranging from 32 - 48 with no apparent reason. Called Danby and took it back to Sams for a replacement. Haven't had a problem with the control on the new one.
Posted on Sep 25, 2007
According to their customer support this is perfectly normal. You are actually one of the lucky ones, holding the temperture between 34 and 38. My unit holds at 42. Sometimes a bit warmer. Buyer Beware! Guess I will be investing in a stout. Something that could be a little warmer when ingested. So much for ice cold beer.
Posted on Sep 24, 2007
  • 291 Answers
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Posted on Sep 04, 2007
  • Mike Johnson
    Mike Johnson Sep 04, 2007
    sorry cant bring up anything on that thing.. sounds like a electronic themostate... there pains... have ya tried to unplug it and see if it will reset to default. Other than replacing it .. not sure what else u could try.
SOURCE:
Today i added a bottle of a/c pro to my 2008 mazda 6 and my compressor stopped working, it rotated and stopped right away , anyone know the problem or solution? Please and thank you
You really should have Manifold gauge set for high and low pressures before messing with AC system. If system was empty, It still needs refrigerant to fill the system. There is a sticker on your hood or firewall or ac evaporator housing showing AC Capacity. Another thing when AC system is being charged, you usually have to jump the low pressure sensor in order to get it in. Please don't attempt this with out gauges.
Jul 14, 2015 | Mazda Cars & Trucks
I bought this control and threw out the manual I didn't realize I needed one it's model no: URC 11-2981 R00 Anyone know how I can use it
Hi Please check the have you inserted 2 battaries (AAA
(x2)).
Search method:
1) Press TV button.
2) Press Magic button and hold for 3 secs
3) Now press 991
4) now press power button
5) now press CH+ button until your television turns off. This may need to press many times.
6) Once turns off, press magic button.
7) Now press Power button. some times TV may not turn on, at that time press any other button.
Volume Lock:
1) Press magic button and hold for 3 seconds
2) press 993
3) press TV Key.
If you require more option please post which option require to you.
Feb 10, 2013 | Televison & Video
I have canon ir2000 photocopier machine and i t is showing e354
Canon IR 2000 copier is showing System Error E000
From my searches online the first course of action seems to be resetting the printer in service mode.
I attempted to clear it in service mode:
1. Press ADDITIONAL FUNCTIONS, #
2. Go to #7 Printer and press OK
3. Go to #4 Printer Reset and press OK
4. Yes = ( > )
However, when I press the yes (>) nothing happens.
Does anyone know why this is not working?
Apr 15, 2011 | Canon ImageRunner 1600 Copier
Lost the instructions for my emgo carbureter synchronizer vacuum gauges. can anyone help..
MOST GAUGES WORK THE SAME. INSTALL THE HOSES IN 1-4 ORDER. START BIKE AND LET WARM UP SO IT WILL IDLE. ADJUST THE SCREWS BETWEEN CARBS UNTIL ALL GAUGES READ THE SAME OR AS CLOSE AS POSSIBLE.
Oct 14, 2009 | 1996 Honda VF 750 C Magna
Display for radio stuck in '7 SAFE' mode
This sounds like a Phillips Car Stereo:
To get the code in:
1. Turn the stereo off.
2. Turn off the ignition
3. Turn the ignition back on (dash warning lights on)
4. Hold and keep down the AS button on the stereo.
5. Turn the stereo on.
6. Release the AS button after 4 dashes appear on the display
7. Now enter code (if code = 7009. Press preset button 1 seven times, button
2 once
3 once
4 nine times
If you go past you can go round again by pressing the
preset button repeatedly
8. Once all 4 numbers are correct hold down AS again until you hear a beep (2 - 5 seconds)
9. The stereo after beeping will scan to program channels
You have 10 attempts to get the code in. However some models will not give you the number of attempts remaining!
Time delays work as follows:
Attempt 1. 10 seconds
Attemp 2. 30 seconds.
Attempt 3. 10 minutes.
Attempt 4. 20 minutes
Attempt 5. 40 minutes
Attempt 6. 80 minutes
Attempt 7 160 minutes
Attempt 8 320 minutes
Attempt 9. 640 minutes (yes that is 10 hours 40 minutes!!)
Vitally important thing to remember, the countdown timer works only when the radio is switched on. ANY interruption in the power will reset the timer!
So, be prepared for a VERY long wait to be able to enter the code!
Oh, and if it has reached 10 attempts, then it needs a dealer unlock.
May 09, 2009 | Car Audio & Video
1993 MAZDA MX 6 STEREO PROBLEM
If you enter the wrong thing 3 times I think your radio is useless
  • Press SCAN and AUTO.M until bars are displayed.
  • While the bars are displayed, input the code number by pressing the channel preset buttons 1, 2, 3, and 4. Press 1 for the first digit, 2 for the second, 3 for the third, and 4 for the last. If you number is 2547, press 1 three times, 2 six times, 3 five times, and 4 eight times. If the dispay goes off while inputing, begin from step 1.
  • Press SCAN and AUTO.M approximately 2 seconds and 'code' is displayed. 'code' will flash for 5 seconds, then disappear to indicate that the system is operable. If 'Err' appears, begin from step 1.
  • !CAUTION: Three consecutive errors will activate the antitheft system, and the audio unit will be completely inoperable and 'Err' will flash. When this happens, the unit must be replaced by an Authouized Mazda Dealer at the owner's expense. Do not allow unauthorized persons to attempt to input a code number.
    Feb 11, 2009 | OEM Systems Car Audio & Video
    Samsung HR733 making multiregional
    1. Press the Repeat button on your remote control
    NB: Do not confuse this with the Repeat A-B button
    2.
    If your player was purchased in Region 1:
    Press the buttons 2, 9, 3, 3 and 4 on your remote control, in order one at a time
    If it was purchased in Region 2:
    Press the buttons 5, 7, 5, 3 and 8 on your remote control, in order one at a time
    For Region 3 players:
    Press the buttons 5, 6, 7, 3 and 2 on your remote control, in order one at a time
    For Region 4 players:
    Press the buttons 7, 6, 8, 8 and 4 on your remote control, in order one at a time
    For Region 5 players:
    Press the buttons 5, 3, 8, 1 and 4 on your remote control, in order one at a time
    For Region 6 players:
    Press the buttons 2, 4, 4, 6 and 2 on your remote control, in order one at a time
    3. The numbers 02 or similar will be displayed on the top left of your onscreen display
    4. Press the 1 button on your remote control for region 1, 2 for region 2, and so on, or 9 for multi-region playback
    NB: The above step may be time sensitive and need to be performed quickly
    5. After 15 seconds have elapsed, power off your player and then power on your player
    Sep 27, 2008 | Samsung DVD-HR734 DVD/HDD Recorder
    161 fatal error C7300
    Try this - WARNING - will reset everything to factory defaults
    The machine must be put back into "Shipping Mode" in order for the consumable counters to reset.
    In order to place the printer back in "Shipping Mode" do the following:
    0.27c?openelement&fieldelemformat=gif
    1. For the C72/74/92/94 models, hold the (1) and (5) keys down, for the C73/75/93/95 hold (0), (1), (6), and (7), while turning the printer power on. (Hold until "MAINTENANCE MODE" is displayed)
    2. Press (0) five times until "ENGINE DIAG MODE XX.XX" is displayed.
    3. Press the (2) and (4) keys simutaneously, "ENGINE DIAG LEVEL 3" should now be displayed.
    4. Press the (5) key once, "LOCAL PARAMETER SET" should now appear on the display.
    5. Press the (6) key three times until "FACTORY WORKING MODE" is displayed.
    6. Once "FACTORY WORKING MODE" is displayed, press (3) once so "Shipping Mode" (Fuse Cut Enabled) is displayed in the bottom line.
    7. Next press and hold (3) & (7) together, until "Shipping Mode" stops flashing.
    8. Power the printer off and back on, now the printer will reset the consumable counters. ecblank.gif ecblank.gif ecblank.gif
    Aug 30, 2008 | OKI C5300n Led Printer
    1998 Honda Accord V6 3.0L LX Coupe --- Temperature gauge issue
    I'm guessing that you have resistance in the wire from the gauge to the instrument cluster or that the grounding is bad somewhere. Still have a problem? Leave it alone because you know what is 'right' or insert a resistor in the line to recalibrate it.
    Jul 24, 2008 | 1998 Honda Accord
    Danby DKC645BLS Compact Beverage Cooler Logo
    883 people viewed this question
    Top Danby Refrigerators Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
