Question about Freezers
Freezer problems have an old Hotpoint upright freezer. freezer runs a lot. relay attempts to start compressor several times before successful, draws down the house lights. temperature control is set at lowest setting. temp in freezer is about 5 degrees F.
  • 291 Answers
You could try a 3 in one hard start kit... comes with a copacitor to help start compressors with age and having trouble starting
Posted on Sep 11, 2007
SOURCE:
Compressor works intermitently
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 25, 2011 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Hotpoint FFA52S , the food in the 2nd draw does not fully freeze
If your refrigerator is running but warm, then...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Jan 05, 2011 | Freezers
Making noise when attempting to start
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 23, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
May 20, 2010 | GE 13.7 cu. ft. General Electric Upright...
Freezer motor cuts in and out. Runs for about thirty seconds at a time. Now have red low temp light on and everything is defrosting. Sides of freezer used to be very warm and are now cold.
Good day,
Some kind of compressor problem. If it will run a true 30 seconds then it is either the start relay mounted on the side of the compressor hanging up and not releasing after the compressor starts or the main windings in the compressor are starting to short, causing the compressor to draw too much current followed by the protective overload shutting the compressor down.
The relay is pressed onto the compressor pins and can be removed.
A parts house should be able to test it for you. If bad, replace. If it tests good then the problem is internal to the compressor and would need the attention of a qualified tech.
P.S. If the unit is under 5 years of age, leave it alone and call for factory service. It may or may not be covered but if so it would be necessary to preserve the balance of the 5 year warranty.
Apr 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Have power and light. can't hear compresser run
could be a bad start relay or start cap. could be a bad compressor. if you have an electric meter you can test the ohms of the compressor and that can tell you if the windings are good, however it cannot tell you if the piston is locked. if you have a locked rotor condition and bad starting components you will not be able to tell until you replace the bad starting components and test run. if it hums and draws lots of amps its locked rotor. most compressors will tell you RLA and LRA amperage, LRA is locked rotor amps, RLA running load amps
Oct 10, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Apr 27, 2009 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezer attempts to start but after a few seconds trips out
There is a relay and protector, these are where the wires attach to the compressor,or rather how the power wires attach to the compressor.You can purchase a 3n1 start kit which has the instructions with it. Be sure to unplug the freezer before touching the wires or attempting to install replacement parts.
Mar 08, 2009 | Freezers
Problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
Feb 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
241 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
