Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Tv shuts down
Whilewatching for a few hours it will shut down, the voice still comes thru, but picture is blank. Shut the TV off for a minute and works fine after that. But last night shut down at least 4 times in two hours. It is away from all and noit close to a heater.
  • rodholder Dec 04, 2007
    After being on for two hours the TV just shuts down and makes me wate about 5 min before I can turn it back on and then it will only last for 30 min until it does it again. I sent it in to Circit Citi to be fixed and they said they had to replace the main bord and now it is doing it again one month later.
  • dukeman75 Feb 25, 2008
    Tv worked fine for 1 1/2 years now it shuts off after only 30-45 seconds. We called Samsung, they said it was the bulb needing to be replaced. We ordered a new one and installed it. Same problem. Called Sears, who we purchased it through. Had a warrenty, but mother cancelled it. Now we're screwed with a 1400.00 tv that is just collecting dust.
    Scholar:
  • 173 Answers
Does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Posted on Jan 26, 2008
SOURCE:
Samsung hl-s5087w.... Tv is 4.5 years old, and is about 200 hours into its 3rd bulb. Yesterday, very similar to when the bulbs burnt out, it shut off. I thought that it may be getting too hot, so after it...
Above the light is a temp sensor with a blue and white wire plug. This sensor is the problem for all these shut downs in my opinion. Pull out plug and jump it with a wire or paper clip bypassing sensor. Tv should work now!!!!
Apr 23, 2011 | Samsung HL-S5087W DLP TV
I have a Samsung HL-R5678W DLP TV that is acting up. When I first turn it on everything works, after 5 minutes it shuts itself off. After 2 minutes it will come back on without sound. It will do this a...
U turn tv on hear any squiling,grinding or motor noises?Picture show up before it shut down picture have flashes of black&white within the picture?Yes,to all of these,this tv have a colors wheel and it dead,require the colors wheel replacing.No,none of these problems.The tv projection lamp,if in this tv like a 1 1/2 or 2 years,tv ben on an watches like 4 or 5 hours a day?The "LAMP" LED light indication lite up or flahes,the projection lamp life is over.Require a new projection lamp.
Oct 22, 2010 | Samsung DLP HL-P5663W 56" TV
TV keeps shutting down.
the power relay contacts are burned replace the relay
May 21, 2009 | Philips Televison & Video
Mitsubishi VS-45607
there is a protection circut that will shut down the tv when it detects a failure in one of the components , when components heat up to much they go into thermal breakdown, the part that is heating up and failing is getting worse , so it will need to be test to determine which one
Oct 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
373 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
