Question about Maytag MAV7600 Top Load Washer
Maytag Atlantis 7600 spin cycle (top load)
I pushed the lid switch with a screwdriver and watched. The wash cycle is fine. The rinse cycle won't dispense the softener, but the water drains. The spin cycle doesn't move, even though it sounds like it is. The clothes are dripping wet.
  • Anonymous Mar 13, 2014
    my maytag legacy washer will advance through all cycles and at the end wash water is still in it if i move it back to rinse manually it will drain and spin then fill for rinse cycle and then i have to move it back manually to begin spin cycle it drains and spins fine then all hoses are clear and pump works fine
  • Anonymous Mar 30, 2014
    Load is wet after spin cycle
  • 625 Answers
The maytag runs in one direction for wash. it reverses to drain and spin - check for a broken or loose belt. maytags I have run into circa 1989 have two belts. as for the softener dispense, there may be a solenoid valve that is supposed to open. may be just a flapper type of valve. softener goes in by gravity feed.
Posted on Sep 05, 2007
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Spins out of control during spin/rinse cycle?
If it has a loud grinding noise, the pump shim is slipping up. It looks like a piece of corrigated cardboard inside the pully in the center of the underside of the tub. Use a flat screwdriver to GENTLY push it back into the pully and order a new pump as this is a temporary fix. The Atlantis is known for this, and the lid switch also. Good luck.
PS Here in SW Florida I paid $50 for the pump FYI
May 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
No rinse or spin cycle
you have to change the lid switch
as soos as possoble
Mar 08, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Maytag MAV7600 Top Load Washer Logo
325 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
