Compaq Presario 5000 PC Desktop Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power light comes on but nothing appears on monitor
So when I press the power button on my Compaq Presaria 5000, the light on the power button comes on, plus the light next to it with a little cylinder picture comes on. The lights on the keyboard flash on briefly, but then stay off. The fan on the power supply and the fan over the heatsink both start up, but nothing appears on the monitor. And the computer doesn't make all the normal sounds it makes when its booting up.
Also, I don't think this is the cause of the problem cause it occured after the problem started, but I just want to mention that when I took the cover off the computer the heatsink fell off the motherboard and is now sitting on the floor of the computer.
I've tried putting in a new lithium battery in but that didn't help. Any help gratefully appreciated
pvc73
Level 2:
  • Expert 95 Answers
  • Posted on Apr 06, 2009
pvc73
Expert
Level 2:
Answers
95
Questions
0
Helped
23871
Points
249
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
My compaq presario V6000 is stop working out of blue..Don't know why..the power cable is connected but hit the power button,nothing happens..any solution ??
Disconnect all cables from the computer. Press and hold down the power button for about 20 seconds. Reconnect only the power cable and try to turn on the computer on pressing the power button If it turns on then good otherwise, switch the power cable of the computer with the power cable of the monitor as they are the same cable as the power cable could be bad but this rarely happens. Open the computer and see if you see any light on the motherboard, if you do then the power supply is bad. If you dont then both power supply and the motherboard could be bad.
My compaq evo d51s is not displaying on the monitor at boot up.
Cleare Bios and replace the RAm if not solved use pci vga card, cirus logic or sis 6326 AGPcard
Can't get computer to turn on (compaq presario 5000)
Either your Hard drive (hd) crashed or your hd cable or port is faulty. if your software is corrupt boot with a boot disk (assume you are using XP or Vista), press R on the blue options screen. you will be given a black dos prompt screen. Type in fixboot and type Y for an answer.
Won't power on
try these solns: (not a joke) it worked sometimes with me. 1. remove the power chord and count for 1 minute then put it back then put it on. 2. reseat your RAM 3. make sure your processor fan is really inplace. 4. reseat your video card 5. make sure your monitor has power, hehe.. if not, well tell me, i may have more suggestions. its hard to know how to fix your hardware with less information.
My computer won't start up. It's a Compaq Presario 5000.
Please provide some more details...
Is power supply comes both monitor and CPU
Is *********** Bord light is on or not
When you press power button bios screen comes or not
Please provide the above questions answer this will help us to catch your problem...
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
2answers
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
2answers
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
