Question about Black & Decker BDTF1010B Tower Fan
I am trying to fix an Oscillating Tower Fan.
My 1.5 year old Black & Decker BDTF1010B tower fan wants to cut off after a few seconds of use. I am thinking it is either the connections with the control buttons or the motor? I can not find ANY information on how to fix these fans.
  • abbottfse May 31, 2008
    fan will not run at all all lights on front panel appear to be operational but fan motor does not run
  • 625 Answers
Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have.
Posted on Sep 05, 2007
  • lazulilu Aug 21, 2011
    You could put some graphite grease on the part that is the rod, where the oscillating part goes back and forth, to keep that lubricated , ALSO CHECK TO SEE if any washers or o- rings need replacement, or a dab of lubricant ... .
SOURCE:
I have this fan and unfortunately don't have a legend for the 5 buttons on top and what they do. is there a manual somewhere that tells me what each button does?
Hello, Chris -
I believe the Hawaiian Breeze tower oscillating fan operates much like the Aloha Breeze oscillating tower fan. I found an image for Aloha Breeze oscillating tower fan buttons, along with descriptions of what each button does.
I am not sure if the buttons on your fan are in a horizontal curve or a vertical alignment. However the attached image should help you figure out what the buttons on your fan represent.
Tower Oscillating Fan Buttons
1. Power - On / Off
2. Speed: slow, medium, fast
3. Timer: May be 15 levels; 1 / 2 hour setting for each timer level; Each touch of the button adds 1 / 2 hour of running time
4. Oscillation: Stop / Start fan oscillation
5. "Wind": Normal, Natural, Sleeping
http://www.fixya.com/support/t10019057-fan_will_not_start_lost
May 01, 2018 | Tower Dryers
Manual for bdtf1010b
Try Googling (Black & Decker)(BDTF1010B)(manual) without parens.
Nov 16, 2017 | Black & Decker BDTF1010B Tower Fan
Owners manual for Enviracaire EFY-047? Remove filter? Thanks
I believe this is the correct Use and Care Manual for your fan:
http://useandcaremanuals.com/pdf/BDTF1010275.pdf
Simply clean the vents with a vacuum cleaner; you should not need to remove. There is no filter in the Black & Decker BDTF1010 Tower Fan.
Apr 18, 2011 | Black & Decker BDTF1010B Tower Fan
After cleaning the fan it quit oscillating?
There is a tip over switch that may have been placed upside down. check wiring
May 15, 2010 | Black & Decker BDTF1010B Tower Fan
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
My oscillating fan has stopped oscillating how can i fix this
pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Jun 30, 2009 | Black & Decker BDTF1010B Tower Fan
when you take all the screws out slide the back down. there is a screw at the bottom holding it from slideing the 9th screw so to speak. you have to take out the u shaped pin on the rod once that u shaped pin is out thats where you will find all the screws to the bracket holding the moter in place take all those out too. it seems like alot but it is really not.
Jul 12, 2008 | Black & Decker BDTF1010B Tower Fan
How do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
May 29, 2008 | Black & Decker BDTF1010B Tower Fan
Black & Decker BDTF1010B Tower Fan Logo
2,001 people viewed this question
Top Black & Decker Dryers Experts
Tom Chichester
Chris Huff
Chris Huff
Are you a Black & Decker Dryer Expert? Answer questions, earn points and help others
