Question about Polaroid I533P Digital Camera
Battery Problems I put brand new batteries in my camera, and about a minute later it says the battery is low and shut off. It has done this more than once. Do you have to have specific batteries?
  • churchlady Nov 09, 2007
    I have the same problem and was wondering the same thing.
    Still looking for an answer.
    dawn
Digital cameras as I have found only used a certain type of batteries. I have noticed that Lithium based work great! also any battery that says high tech device works.
Posted on Dec 27, 2007
I had problem with the "brand new" battereis that came with camera (date on batteries was thru 2014) ... after 2 or 3 pictures ... camera would not work. I replaced with fresh batteries ... works great now. I checked voltage on shipped batteries (that came with camera) ... was about 1.3 volts ... new battereis should be 1.55+ volts. This suggests that shipped "brand new| batteries ... are not "brand new". I called Polaroid .. best I got was "sorry" ... and "call Duracell".
Posted on Dec 11, 2007
SOURCE:
2002 mercury montaineer , battery light comes on , they gages shut down couple minutes after then the truck acts like it gonna shut off....when getting a jump, the truck fires right up, couple minutes...
Your battery is definitely low. First clean the terminals on the battery and the inside of the terminal rings on the wires. If you have a slow charger put it on that overnight and see if it holds a charge. If it still keeps depleting or doesn't charge overnight then either your battery or your alternator are done....possibly both. So take the battery to have it load tested. Most places that sell them can test them. If the battery is done replace it then test the battery with a volt meter. If the old battery is still good put it back in the vehicle and test the voltage with a volt meter. With the engine off the voltage should read 12 volts (once its fully charged or if its new) with the engine running it should read around 14 volts. If it is way higher than that or it doesn't go up at all your alternator requires replacing. Alternators are fairly easy to replace but if you don't feel comfortable with that take it in to a mechanic.
Jul 25, 2011 | 2002 Mercury Mountaineer
My canon SX110 IS camera has recently started displaying 'battery is low' and flashing the red low battery sign even a few minutes after putting in brand new batteries. I have tried with several new sets...
I had the same problem with new batteries reporting as "low" and instant shut-off. After I found that it would stay on when plugged into USB, I suspected a firmware bug in the camera (I am a computer engineer). So I thought "how can I fool it?" I then found that it would stay on if you power it up with the rotary dial BETWEEN the video and manual ("M") setting -- in the "illegal" position. The after it's on, every mode works!
--Dan S.
Ithaca, NY
Oct 22, 2010 | Canon PowerShot SX110 IS Digital Camera
It says low battery and shuts off
update the firmware using Olympus Master > update camera
Sep 27, 2009 | Olympus FE-210 Digital Camera
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
Beeping camera
Mine did the same thing for forever and was brand spankin new... When the batteries go dead once, I guess it glitches... You can put brand new ones in and it will Still say low battery or act like it anyway. Give it some time. Then try to turn it on again and it will be fine. Also it will say you have a low battery if you are taking too many pics at a time... like snap snap snap and it will shut down... turn it back on in twenty minutes and its fine... full battery. If you can't deal with this... Get a battery charger and rechargable batteries. I am using them now with none of these problems
Jul 07, 2008 | Samsung Digimax S730 Digital Camera
Polaroid I533P Digital Camera Logo
230 people viewed this question
Top Polaroid Cameras Experts
Ekse
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
