I have a 2004 jeep liberty. Recently I had to replace the left rear tail light due someone hitting it. After I replaced the external light, I started to have lighting issues. Initially my front left turn signal light would come on when I hit the brakes. I pulled the left rear light to make sure something did not disconnect. After that, it did not turn on when I hit the brakes. Now when I turn the lights on, the left turn signal light in the front and the rear brake light do not turn on. The turn signal will work when I turn the blinker to the left and the brake light will work when I hit the brakes. I am not sure if it is a fuse or there is something else going on.
Did the new lens come with new sockets? If not damage may have occured there that you cant see. only other possibilty is wiring damage in the rear that may be hard to see. The condition you describe is simple "backfeeding" if you look hard enough youll either find bad sockets or damaged wires close to the lens that took the hit. Hope this helped. Thanks
Turn signal tail lights and BRAKE LIGHTS NOT WORKING
It
can be faulty brake light switch causing the problem or its blown brake light bulb.
First check and confirm brake light lamp is working and that's not
the case.
For turn signal not working it can be faulty turn signal switch or its issue with wiring:----
To
trouble shoot brake and turn signal related problem, check the help links mentioned
below:-----
Click
the link:----
1996 Buick Regal Grand Sport Brake light
Switch Location?
http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
No brake lights on Buick?
http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
Brake lights not working on 1989 BUICK REGAL?
http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
How to replace Brake light switch on Chevrolet Tahoe?
http://technoanswers.blogspot.in/2012/02/how-to-replace-brake-light-switch-on.html
How to
replace Parking, turn, and Brake Lights on car?
http://schematicsdiagram.blogspot.com/2011/06/how-to-replace-parking-turn-and-brake.html
Upper brake lights work,
but low brake light not working?
http://schematicsdiagram.blogspot.com/2011/12/upper-brake-lights-workbut-low.html
1997 Cadillac Catera: How
to replace Brake Light Switch?
http://howtobyme.blogspot.in/2012/06/1997-cadillac-catera-how-to-replace.html
2003 Chevrolet S10 Tail light Fuse
http://schematicsdiagram.blogspot.com/2012/11/2003-chevrolet-s10-tail-light-fuse.html
Chevrolet Parking light and Tail lamp light
Wiring diagram
http://schematicsdiagram.blogspot.com/2012/11/chevrolet-parking-light-and-tail-lamp.html
Car Tail Lights Not Working?
http://schematicsdiagram.blogspot.com/2011/12/car-tail-lights-not-working.html
Turn Signal Not working
http://technoanswers.blogspot.com/2012/11/turn-signal-not-working.html
Right turn signal not working on Pontiac Car?
http://schematicsdiagram.blogspot.com/2011/12/right-turn-signal-not-working-on.html
Only one side indicator light working on car?
http://schematicsdiagram.blogspot.com/2011/12/only-one-side-indicator-light-working.html
Turn signals not working on 1987 Jeep
Wagoneer?
http://schematicsdiagram.blogspot.com/2011/12/turn-signals-not-working-on-1987-jeep.html
1996 Chrysler LHS brake light circuit wiring
diagram?
http://technoanswers.blogspot.in/2012/02/1996-chrysler-lhs-brake-light-circuit.html
How to replace rear Brake
lights on 2004 Toyota RAV4?
http://schematicsdiagram.blogspot.in/2012/02/how-to-replace-rear-brake-lights-on.html
One brake light on driver
side not working, but other lights work?
http://schematicsdiagram.blogspot.com/2011/12/one-brake-light-on-driver-side-not.html
2002 Lincoln Town car Fuse Box
http://schematicsdiagram.blogspot.com/2012/11/2002-lincoln-town-car-fuse-box.html
2007 KIA Rio: Brake Light Fuse Box
Diagram?
http://repairhelpcenter.blogspot.in/2012/06/2007-kia-rio-brake-light-fuse-box.html
Overhead Brake lights not working on 1999 GMC
Sierra 4x4?
http://technoanswers.blogspot.in/2012/03/overhead-brake-lights-not-working-on.html
2004 Ford Mustang: Brake
light Fuse Location?
http://howtobyme.blogspot.in/2012/05/2004-ford-mustang-brake-light-fuse.html
These
will help.
Thanks.
