Question about Kenmore 23822 Top Load Washer
Rinse my kenmore elite gets to rinse and just sits and does nothing all day
  • 625 Answers
If it uses a mechanical timer, the cam that operates the spin contact is burned up. mechanical timers can cost around $130 from maytag. go to the whirlpool site. maytag was bought out by whirlpool.
Posted on Sep 05, 2007
SOURCE:
Unlock door on kenmore elite 110.4996
turn the power off
and let the machine sit for 5 mins
if it still wont open then the door interlock has frozen up
and youll need to pry it open
best leave this too a tech
its a grim job anyway
and worse if you have no idea what to do
Feb 08, 2015 | Kenmore Washing Machines
Bought in 2006 and quit working all together in 2007 then pulled it out today and the thing started working until the end of the wash cycle and wont come on at all again... it drained well but at the
Hello Kimberley,
It appears that a part of your question is cut off so i may be off base here but what i am reading is that your washer will go through the wash cycle and drain the wash water then just quit?? is that what is happeningIf yes that is whats going on i think what is happening is that after the wash cycle it fills with only COLD WATER for the rinse cycle and its not filling with the rinse water and just sits their until the rinse cycle water is filled and if its not getting cold water into the washer its not going to do anything If it is filling with cold water my apologies my bad for misinterpreting what the question reads and i ask ya to re-ask it.
GENE
Nov 03, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite dishwasher gives a message "Rinse Aid Empty". What does this mean?
It means the rinse aid dispenser is empty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite went through a cycle, but didn't spin on the final rinse. diplay screen is flashing F then H. F then H. what is going on?
The F/H code means the unit isn’t detecting water fill at the flowmeter. The flowmeter sits just in front of the inlet valve and is attached via a hose, and off to the left of the CCU. If your washer is filling ok, check the wiring from the flow meter to the control board; I’ve seen this harness jiggle loose and cause problems.
hope this helps you...
Oct 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Elite is not going through the rinse cycle and is flashing "H". It also isn't even dispensing the fabric softner from the dispensor. Can you help?
Will machine fill with both hot and cold water? Sounds like it's not getting cold water in. Check your screens on the water valve where hoses connect. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 23822 Top Load Washer Logo
55 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
