Question about Maytag Ensignia MAV2757AWW Top Load Washer
Water comes back in
After final rinse and spin the washer gets about 2 inches of new water at the bottom and has to be spun again to drain this. Is there a reset button or something that will solve this.
  • tmack Sep 08, 2007
    yep even up to 4 times. I think I am going to get brave and see if there is a blockage from the drain tub. seems like alot of screws. Is tis easy to take apart and look at?
  • 641 Answers
Does after the second spin the tub fills with water again or stay with no water ?
Posted on Sep 04, 2007
  • Dov Dror Sep 08, 2007
    You are right,it sound like you have a blocked pump. Don't worry to do it by yourself it's not so complicate as it seems to you.
    Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it.
    To access the pump, first bail and sponge out any water in the machine's tub. Then tip the washer over on its front, using a heavy blanket or pad to protect the washer's finish. Remove the back service panel. The pump is usually located along the right side of the bottom of the machine, but with the unit tipped on its front it's easier to remove it through the back than through the bottom of the washer.
    Locate the pump. It has two large hoses attached to it with spring or strap clips. If the clips are the spring type, pinch the ends of the clips together with pliers to release them, and slide the clips down the hoses. If the clips are the strap type, unscrew the metal collar to loosen the clamp. Disconnect the hoses by pulling them off the connections. If the hoses are kinked or crimped at these connections, straighten them as best you can and reconnect them.
SOURCE:
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't drain or spin
you need to check the water pump... it may be clogged with detergent or something to that effect.. or just replace the pump itself..
Oct 11, 2009 | Washing Machines
The final rinse isn't rinsing thoroughly. I have
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 30, 2009 | Kenmore Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Help Guru Please
Ill try,
first off its normal for water to spray in during the final spin( its a spray rinse), as far as the water coming back into your machine after the final spin stops, you have an issue with oyour drain, i would assume that the drain hose is NOT going into a stand pipe"open drain", but instead clamped to another hose leading outside or to a drywell, in which case youll need to install a "one way check valve". whats happening is after the final spin is done al;l the waterin the drain line is reurning back formn the drain hose.Proper insstallation will cure this.
lastly its hard to describe"slower than usual spin" it will progressivly spin faster as moire water is removed form the machine, i wqould rectify the drain issue before i concern my self with this( and make sure you not selecting a :gentle spin" option of coarse... hope this is helpful to you!
Jan 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Amana NTW5245TQ1 Topload washer....water draining out from basket...
Unfortuneately, I think you have two seperate problems. Fortuneately, this is easy to verify. As far as the not spinning, it is generally caused by loose hinge screws on the lid. There is a arm that sticks off the back of the hinge to press on your lid switch. If the screws are loose, the arm generally wont be able to press the switch. Just tightening ther screws on the right and left hand sides of the lid corrects this. You can verify this has corrected the problem by setting the washer to spin without adding any water. As far as the leaking. Well, there are multiple sources for this, but the most common is the water pump. To verify this, unplug your unit and pull it out from the wall. Tilt the top of the washer back towards the wall until it rests by itself at about a 45 degree angle. You are looking for a white peice of plastic towards the bottom front of the machine. There will be 2 black hoses going into it. run your finger across the front side of it feeling for bumps. You may have had something get lodged in there and poke a hole. If you can not find any moisture on the pump (yes it can leak from the hoses of back of the pump also)look for any signs of water having leaked. (you generally get water spots just like in your dishwasher when you don't use a rinse agent). If you still can't see anything, tilt the unit back forward and add 1 cup of water to the machine. Tilt it back again and see if it's leaking. Continue adding water until you can get your leak then trace the water back. However, if you do in fact have a bad pump, they are availible from local appliance parts suppliers (in the phone book) or on-line from the maunufacture. Any troubles or other problems? Drop me a line back. Otherwise,
Jul 10, 2008 | Amana NTW5400TQ Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Maytag Ensignia MAV2757AWW Top Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
