FixYa.com
Tags:
Jensen PS2130 Car Audio Amplifier
LED turns on, but power light doesnt and there is...
posted by dwsmokey420 on Sep 04, 2007
My amp worked fine for a while, then just stopped working. I looked inside and there doesnt seem to be anuthing wrong with the board. The LED behind the Jensen logo will turn on, but the power light wont.Also there isnt any sound coming from it. What is the problem, and how do I fix it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 06, 2007
Thanks for Trying (70)
conspiracy
Rank:Master Master
Rating: 74%, 5 votes
it sounds to me like you have a bad ground or a short in the ground wire. try checking the ground cable as well as theremote wire (blue), and make sure the ground is connected to an unpainted,clean surface such as the frame of your car.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Sep 18, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
again, NOT A SOLUTION< but Everywhere i go and ask, i am told to take it to a place that specializes in stereo equipment. but if i knew what needed to be fixed in the board, i could fix it myself, WISH I KNEW WHAT HAD TO BE DONE!!!!!!!!! I guess i will just keep trying
Solution #3
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Not that this is a solution but i too am having the same exact problem and the ground and remote wires are properly connected...my ground is good and no shorts but still no full power to the amp....i do hope there is a higher more relevant solution to this issue because im suffering from the same problem :-(
Can you Help with these Car Amplifiers problems?
Car Amplifiers
genon avr1601
Hi gud day i have genov avr1601... Answer This...
Car Amplifiers
i need a code for a universal...
code for a remote control... Answer This...
Car Amplifiers
schematic for washburn pg 65 c
need schematic Answer This...
Car Amplifiers
NASHVILLE DAB35
CONECTARE Answer This...
will like to know how to go to...
installation for amplifier... Answer This...
Repair Service
Find Car Amplifier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
