Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Light blinking...but not coming on
Hello, I have the sony model KP-46WT50C(?) or KP-46WT500 (last digit/alphabet is illegible). Every time I try to power it on, it makes a clicking noise as if it is turning on, but I never get a picture nor any sound. I've noticed the red timer light that blinks on and off, but I do not know what it means. Please help. I haven't had the television 2 years
    Genius:
  • 1,139 Answers
This looks like a problem with the H Voltage or switching power supply section of the TV set. What you need to do is to measure the voltage from the HV transformer to the Anodes of the CRTs with a high voltage probe, and check the voltage output of the switching power supply. What may have happened is a component may have shorted out causing an over-current condition with is triggering the shutdown circuit (These are the relays you are hearing). I would check the Horizontal Output transistor, and the components in that section of the TV.
In addition check the voltage test points on the HV / Horizontal and switching power supply board. This will determine if the section is working or not (most likely not). Make sure you have a schematic, and multimeter and a high voltage probe.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 26, 2007
SOURCE:
My Sony KP-46WT500 TV does not turn on. Red standby light blinks and goes out.
possible bad convergence chips and the two fusses in the power suply or bad tube I need to know how many times does the stand red led flashes after it powers down
Aug 29, 2010 | Sony KP-46WT500 46" Rear Projection...
Replaced a convergance chip..(ps8003) now tv
hello Eight GA_googleFillSlot("TL-IMU-Article"); blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board
regards
shaun
Feb 24, 2010 | Sony KP-46WT500 46" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
No picture or sound. standby light on front panel
The light is blinking a repeating error code. Try to determine the number of blinks before a slight pause as that will be an error code. Then respond to this same post and I will assist you with diagnosing what may be causing the set not to power up.
Dec 11, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Tv goes off then red blinking light comes on
Hello it is the bulb the bulb's on the Rear projection tv are ****. Buy  new tv cause it costs alot to have these tv fixed.
Jan 10, 2009 | Sony KP-46WT500 46" Rear Projection...
No picture on sony rear projection
How many blinks is it blinking before it pauses? Let me know your set is going into protective shutdown. It should blink a number of times then pause for a second, then blink again. Try to count the blinks in between pauses. Then let me know
Jan 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony 46" RPT color problems
Hello BlueKalel,
It looks like your green CRT is malfunctioning. You should try to see if the voltages are correct on the socket of the green CRT and check the high voltage on the green CRT using a high voltage probe. Use a schematic diagram to reference these voltages to.
I am positive that the problem is the green CRT or the circuitry leading to the green CRT. Please use caution when checking these voltages.
Thank you,
Shuttle83
Sep 29, 2007 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
133 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
