The screen and the keypad got wet its been drying for about a few months now and when i turn it on the keypad light comes on and the screen lights up a little everything else works sound and all but the screen stays blank. what do i do please help...
Put it in front of a fan and let it dry out for a few days. You can also try using a hair dryer to dry it out faster. Then try turning it on again. Hopefully you didn't short anything important out already by turning it on too soon.
Call sears and they can tell you normal cycle times according to your model. 1888.536.6673. Maybe argue with them to replace this unit since so many issues within 5 months.
I helped a friend with a similar problem using the solution below, so I am sure it will work unless your phone has shorted out:
Remove the battery from the phone immediately -- preferably right after it had gotten wet.
Spray the phone liberally through the keypad and inside the battery compartment with a good brand of electronic cleaner such as "CRC QD Electronic Cleaner Quick Drying Formula". It is important for the cleaner to get into the phone to wash out any water and mineral residues as they can cause a short when you put the batteries back into the phone.
Allow it to drain and dry, or better, blow dry it with hairdryer set on cold, or turn upside down on your dashboard for a few hours. Do NOT put the batteries back in the phone while it is drying.
When your phone is completely dry, put battery back in and turn it on. If it does not come on, put it on the charger. You should see the indicator come on showing "Charging".
After a few minutes to a half an hour, try turning your phone on. It should work if nothing has shorted.
When these phones get wet, there is perminent damage. The fix is to swap out the circuit boards that become damaged. It is cheaper to buy a new phone rather than fix it.
u must let your cellphone dry up b4 u turn it on,1st thing to do dismantle your cellphone case then u can use a hair blower to dry it up. then try to turn it on. if its not working maybe your cellphone suffers a shortcercuit
sorry to say this but a wet phone is ruined. You will have to take it to a tech at your phone server. They will either repair it or you will have to get another one. Water and phones do not go together at all. Sux.
