Washer does not spin but makes loud clicking noise?
sounds like you could have a problem with your basket drive tube,around the clutch brake area! my machine would not spin and i found out the bottom of the basket drive tube had been ground off by the thrust washer which resulted in the clip that holds the brake release arm fell off and broke the 2 little pins on the brake release arm and it would not disengage the brake to allow the basket to spin, i bought a used basket drive tube and a new clutch ,installed and unit works fine now,,,so take a look also check your motor coupling see if it is broken ,,, and 1 more thing ,up under your agitator is the basket drive block sometimes it shears off the notches on the top of your drive tube!
