Question about Sanyo DS27820 27" TV
Video mode I can't find my remote and my tv is stuck on video mode. When I go into menu I'm only able to change the language and color. How do I get it out of video mode?
I just bought this same TV at a yard sale today. There was no remote and it had the same problem. I used autoprogrtam feature of my cable remote to use the TV part of the that remote. With that remote I was then able to change video inputs and access all the menus properly. Good luck, Dan
Posted on Sep 08, 2007
SOURCE:
Can't change language on tv
As far as the Banner goes, go into menu, shut off "store mode" or "demonstration mode". Language change should not be stuck.
Jan 14, 2014 | Hitachi Televison & Video
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
Sep 15, 2011 | Sanyo AVM-3259S TV
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
My remote stopped working and my tv is stuck on video 2. Is there a way to get it back to a regular screen without the remote? when i go to the menu button it only allows me to change the language or the...
There should be a button on the TV "INPUT" press to change sources. It should be on the front lower center of TV, slide panel to expose if required. Put new batteries in remote.
Aug 21, 2010 | Sanyo DS20930 20" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
No remote - can't get tv off of aux mode
most zeniths change just the channel up or down takes if off video/aux. Its usually below channel 2. otherwise need remote
Jan 08, 2008 | Zenith C13A05LG 13" TV
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
Aug 23, 2007 | Sanyo DS27820 27" TV
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Aug 20, 2006 | Sanyo DS27800 27" TV
Sanyo DS27820 27" TV Logo
294 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
