Question about Teac CD-RW880 CD Player / Recorder
CD-RW880 records only 10-15 minutes then stops
Lately, my Teac CD-RW880 stops recording after 10-15 minutes into the session. I didn't realize this until after listening to a recorded CD. I wasn't watching it while recording (a hypnosis session). My client called to let me know that the CD stops playing 10-15 minutes into the session. I tried again and it got the same problem. I can't fast forward beyond a certain point. I can't skip into the new area. It just stops recording. HELP!
  • berkhyp Sep 04, 2007
    I'm afraid you may be right. I've been using this recorder for a few months, having made roughly 30 recordings onto the same media (I haven't gone through my pack of 50 disks, yet).
    I can't find another possible reason.
Berkhyp, did you ever figure out a solution to this issue? I am having the same issue with our Teac CD-RW880. Did you bring it in to get it fixed. I'm wondering if it is even worth fixing?
Thanks.
Posted on Dec 17, 2010
  • 112 Answers
Sounds like either the grease on the laser rails has soldified making it difficult for the laser to push part it(easy fix)or some teeth have stripped off the gearing that moves the laser ( not so easy) - first thing to try is take the casing off,and use a q-tip or similar to run down the laser rails with the tray out of the unit.
Posted on Jan 28, 2008
Hi i would say try other cd recordable media but it sounds like your player has a tracking/laser pick-up problem or a laser mechanism fault,i would suggest you take it to the nearest repair agent to get them to look at it for you. regards. paul.
Posted on Sep 04, 2007
CD-RW880 led screen reads DIN-unlocked
There's a manual for that...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Teac-CD-RW880-CD-Players-review-manual/id/3875dj898/t/1-2/
Page 23. Non-functional digital input. Check the cable.
Jun 30, 2011 | Teac CD-RW880 CD Recorder
My Teac CD-RW 880 CANNOT GET THE DIN-UNLOCK OFF. CANNOT RECORD WORKED FINE BEFORE.
DIN in this context stands for Digital IN. It'strying to tell you that it can't see a good digital signal from the source.
See page 16 and 23...
http://www.retrevo.com/support/Teac-CD-RW880-CD-Players-manual/id/3875dj898/t/2/
Apr 06, 2011 | Teac CD-RW880 CD Player / Recorder
How do I see the manual for the teac 880 cd recorder before I order one. Thank You
Go to http://www.manualnguide.com/download/manual-guide/teac-cd-rw880-cd-recorder-owners-manual.html and download the manual. You need a PDF reader
Jan 29, 2011 | Teac CD-RW880 CD Player / Recorder
Read error
Some recorders, especially Phillips REQUIRE using the "Music" CD's. It was a lame attempt at copyrright enforcement.
Dec 15, 2009 | Teac CD-RW880 CD Player / Recorder
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Discs will not eject, unit makes strange clicking noise
HI, the gear track is stripped and the load motor is stuck between the good section of the track and the bad section of the track. you will need to replace the loading dock in your unit. this will fix this issue.
May 27, 2009 | Teac CD-RW880 CD Player / Recorder
I need the ir remote codes for a teac cd-rw880
http://dogbytecomputer.com/codes.htm#CD%20CODES
Feb 13, 2009 | Teac CD-RW880 CD Player / Recorder
Read error
try a cleaning disc. Your lens may be dirty
Feb 02, 2009 | Teac CD-RW880 CD Player / Recorder
Teac CD-RW880 CD Player / Recorder Logo
204 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
