SOURCE: Bosch nexxt 500 series dryer
I had the same trouble after moving to a new house, I first thought I had a voltage problem. It turns out that the heating coil has a high temp re-setable switch in side the back - lower right side. the sencor has 2 screws, I took it out and cleaned off the lint and now have dryed 5 loads with 0 issues. looks like a flaw in design that would allow lint to get in the heating coils!!!!! I think I'm going to look for a new dryer before I burn down the house!!
SOURCE: Bosch Nexxt 500 series dryer, E:01 and lint light
This indicates the sensor near the lint filter gets too hot. This is usually caused by bad air flow.Try running the unit without the vent hose attached. If the problem goes away the problem is in the ducting.
You may need to have it cleaned out. May be lint filter is clogged due to the use of dryer sheets or fabric softener. You can try to clean the filter with Windex.
If neither one of this suggestions resolves the issue there may be a problem with the sensor, there may be heat escaping somewhere within the dryer. This is only resolved by technician.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
SOURCE: Bosch Nexxt 800 series dryer E01 error
My wife has a Bosch Premium dryer that had drying problems. The lint filter would get cleaned but the machine still did not operate correctly, as you explained above. Her machine was made in 2005 and the lint screen, the plastic slotted unit in front of the lint filter was the problem. It gets clogged up with hair/lint that never makes it to the filter. I tried a shop vac to vacuum it but the problem was still there. Get a pistol cleaning kit for a 22 cal gun. Pull the lint filter out & then take the pistol rod and insert it from the drum side into each slot and pull out the tons of lint. Pull the lint off the rod when done and take a flame to burn the rest off as the rod is a brass brush with small wires on it.
