Question about Sharp 27L-S300 27" TV
Green hue instead of actual colors
After relocating my Sharp 27L-S300 TV to a different house, the picture is basically green in tint and no other colors. The TV worked fine before the move. I've attempted to use the MENU button on the remote control, but I don't see any options that I expected (as in the "old" days, hue, color, tint, etc.) I'll appreciate any guidance you can provide to get this reliable TV back on the road again. Thanks Gary
    Genius:
  • 1,153 Answers
Short on the crt board, look in the green area. Probably an small 3 leg transistor.
Posted on Sep 04, 2007
SOURCE:
Color and tint looks different. There is a green hue to the screen, and adjusting the tint and color does not help.
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
May 10, 2010 | Insignia IS-LCDTV32 32 in. Television
Green hue/tint
Need to do the alignment feature where it refocuses the light beams. Convergance. Look through the set up. Different magnetism and shaking of the set has thrown it off most likely. Auto focus maybe what its called.
Apr 15, 2010 | Sony KDS-R50XBR1 50" HDTV
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
Sony FD Trinitron WEGA KV-24FS120 24" TV Color changes
Try turning down (off) the color during such an episode. If the image is tinted pink or green instead of black and white when you do this,you have either an intermittent short in your CRT (tube), which is terminal,or a gun drive problem, which may be repairable. If you're feeding it component instead of composite signal,it may just be a bad connection of the B-Y cable.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sharp 27L-S300 27" TV Logo
289 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
