Question about Samsung SCH-i730 Pocket PC
Samsung battery As I charge my battery the light is blinking different colors. It also was on the charger all night & didn't charge. Can someone explain what the different colors mean?
  • Anonymous Aug 08, 2008
    My phone knows that it's plugged in (there is an indicator on the top of the homescreen) but the charger's LED is not even on. It did blink red once when I removed and replaced the battery, but I can't get this to happen again.
    New Friend:
Green:Fully charged
Amber:Improper connection
Red:Charging
Posted on Aug 30, 2012
What Does The Flashing Orange / Amber Light On My i730 Cradle Indicate?
A blinking orange or amber light on your cradle normally indicates a bad connection between your phone and the cradle. Anytime you see an orange light on the cradle, we recommend reseating the phone in the cradle. The light indicators on the cradle are as follows:
  • Green - Fully Charged
  • Red - Charging State
  • Orange/Amber - Improper connection, battery not charging.
Posted on Jul 01, 2008
SOURCE:
I have a skyforce gravity r/c helicopeter trying to fix for my son.When it is plugged in the charger, it just blinks green light. Have it over night, and it is still just blinking green. Have lost remote....
It means that the charged battery is full. Some chargers have a steady glow, others have a flashing light to show that the battery is charged. When you run the helicopter, is the battery fully charged, does the helicopter blades spin flat out? If so, the battery is charged and the flashing light indicates the battery is charged. If the battery isn't charged or the blades don't spin enough to lift the helicopter, or fly for some time, then the battery isn't charged and the charger may be faulty. Take it to a hobby shop to see where the problem lies, the charger and its blinking light, or the battery.
Dec 28, 2014 | Toys
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
My mobile didn`t charge the battery
it might be the battery you should try using a different charger  and also you should see if any of the pins from phone is damaged you could check it out by looking in the charging hole.
May 30, 2009 | Samsung SGH-X480 Cellular Phone
Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
May 30, 2009 | Samsung SCH-u740 Cellular Phone
The laptop doesn't want to charge!!!
Is very possible that the battery is dead, Check the LEDs on the battery itself, sometimes you have to deattach the battery for can to see them.
If the LEDs blink or not light in sequence (one one, the next off and so on) then your battery is gone, if everithing seems to be right there then the problem is the charger, try with other one.
if charger is good then the problem could be in the circuits that manage the energy in the motherboard.
Good Luck!!!
Feb 26, 2009 | Samsung V25 2400 (NV25NP0H2R/SUK) PC...
My Phone dont want to charge
Try to turn off and on the phone. If that still does not work try to use a different charger. Sometimes even if the light is on the charger does not charge.
Feb 06, 2009 | Palm Treo 500 Centro
Samsung SCH-i730 Pocket PC Logo
897 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
