Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp AR 5316
I have a sharp copier AR 5316 shows error H2 when turned on. what is the error?
  • Studio p Nov 04, 2007
  • Anonymous Mar 24, 2014
    i cant reset password
It worked thanks alot.
All I did was to press the #,interrupt,c,interrupt in sequence. The display then went off.
I then press the numeric keypad 1,4 and start botton in sequence.
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
Posted on Dec 03, 2007
  • Syed Reza
    Syed Reza Dec 07, 2013
    ther is one crrection: that is you have click #,interrupt,c,interrupt very fast ,otherwise the fault will not clear and after that the other sequence will be as like as mentioned above.Thank you
It's fine now.
A big thanks
Ometan Goodluck
Nigeria
    Problem Solver:
  • 13 Answers
There might be some dirt on thermistor above the heater upper roller pls check and clean the fuser unit then use simulation 14 to reset the machine enter simulation by presssing #,interrupt,c,interrupt in sequence display is then off, then no. 14 then start key h2 disappears ok
Posted on Sep 06, 2007
SOURCE:
My problem is error h2
h2 is a fusing/fixing unit problem.also check connector of fusing/fixing unit.
Jul 06, 2012 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 ERROR I have a digital copier Sharp AR-5316. It only puls a 2 and a H
H2 : mean thermistor is defective.
to resolve this problem you have to choice if the first one didn't work go to the next one
  • do the following procedure to reset the error :-
press "R" key __ "Interrupt" key __ "C" key __ "Interrupt" key __ "14" __ " ready" key
  • If the first procedure didn't solve your problem contact your customer service center to replace fusing thermistor.
thank you for using fixya
Feb 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR 5316 im facing #2 or H2 error in my copier please help me and tell me what is this and what is solution for this i am waiting of your reply thank you
On a sharp machine. Press P * C * .... or # * C *. The machine should enter diagnostics mode. then enter 14 then one and press start. That should clear the issue
Oct 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Pls help for sharp copier AR-5316 error code 2-H
H2 signal is thermistor open
check the harness and the connector between the thermistor and the PWB use TC 14 to clear the self diagnostic display.
Oct 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR 5316 is blicking h and then 2 please wat do i do...and pls how many copy can i make wit it in a day
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
Apr 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
721 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
