Question about NetGear DG834G Router
Can't connect to internet thro wifi
I'am having problems connecting to internet using wifi, despite the fact that a 'connection' is established. I don't have any problems using ethernet connection and internet on same computer. I have changed security setting from wpa to wep. Any advice out there?
  • 2,961 Answers
Go to control panel and network connections, right click on the lan connection but not the wireless one and select dissable as the router may still be assigning the wired adapter an ip address. make sure in the wireless cards properties that obtain an ip address automatically on the TCP/IP line properties is selected. Firstly dissable wep to get the connection and then when up and running then apply wep or wpa again but make sure that the security code is set correctly at either 'Open' or 'shared' in the router.
Posted on Sep 05, 2007
How do I enable the wireless internet connection in my laptop? brand is fujitsu fmv lifebook#FMV-E8250?
go to control panel, click on internet connection click on establish find the wifi system in use then enter the code for the wifi system and it connects
May 26, 2017 | Fujitsu Computers & Internet
Can't establish a reliable connection to the server
Internet / WiFi problem.
Thanks, Aaron Duce
Any more problems email me at!!
Nov 29, 2013 | Datawind UbiSurfer 9" Netbook
How to convert a tata photon in to a wifi connection
First, you need an internet gateway. Do you have already some kind of internet connection through DSL, CABLE Modem, etc? The TP wifi will first have to be connected to your network (wired LAN). Then, once that is done, you need a computer with web browser to access and configure the setting in the TP. There is a CD that comes with the TP. It contains "Easy Setup Assistant" program to configure your TP wifi.
Feb 15, 2013 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
I can't connect to the wireless Internet despite
Borrow other wireless adaptor, then plug it to your desktop. Try to connect ...but U must install the adaptor driver too. If it works, that means your internal adaptor is out of work.
Jan 01, 2012 | Acer Computers & Internet
My X3 will not get connected to WiFi. The AP is listed usable, internet connection is automatic and eventough I force connection (by pressing long the AP identity in saved WLAN networks menu) and the wlan...
Are you positive that the connection is not going through your Wifi??
I have an HTV Evo and when I am connecting to the internet through the Wifi, my 3g will show up regardless.
Mar 29, 2011 | Nokia X3 Cell Phone
Have an acer Aspire One netbook and for some reason I cannot connect to the internet even though it is saying that a wifi connection has been established. This has never happened before
If you are connecting on an open WiFi (does not have WEP or WPA enabled), then make sure you are connected to the correct SSID (wireless ID) and not on some other open SSID. If you are on the right SSID, check that you don't have limited connectivity due to low signal strength. If OK, then open Internet Explorer to use its Diagnose Connection Problems tool...
1. click on Tools tab
2. click on Diagnose Connection Problems...
3. click on Next button and follow the steps
If unsuccessful, try powering off the wireless router and the cable/dsl modem for a few minutes and then powering up the modem first followed by the wireless router. Once the netbook has re-established the WiFi connection, repeat the above procedure to Diagnose Connection Problems. Finally, if still unseccessful, connect directly to your wireless router using an ethernet cable from one of the four RJ-45 LAN ports on the router to the netbook's 10/100 ethernet RJ-45 port on its left side. A LAN connection icon should now show in the bottom right of the Desktop's Toolbar. Hovering the mouse cursor over it shows the Local Area Connection pop-up with Speed and Status. If Status is connected, then open Internet Explorer again and use its Diagnose Connection Problems tool to check connectivity to the internet. If still unresolved, the next step would be to log into the router to check its WAN status and depending on the results, you may have to contact your Internet Service Provider.
Jan 31, 2011 | Acer Aspire One Netbook 8.9" Notebook
Tells me Unable to connect to Server
My iphone 3g is unable to connect to internet , even though it gets connected to my WIFI modem. Cant vierw any mails of cant even connect to websites thro safari or to Itune store....
Jul 16, 2009 | Apple iPhone Smartphone
My toshiba satellite x205-s9349 cannot connect to internet
Despite wireless connections being susceptible to EMI, bluetooth signals do not tend cause the kind of interference that would prevent you from picking up a wifi signal. You say the wifi switch is on, but the bulb is red. (It is supposed to be red, that indicates its powered on). The things to check are to see if you are detecting the wireless signal, are you inputting the proper protocols for any known established wireless Security (WEP/WPA). Are you using a wired connection to get on the internet or another computer/location?
Dec 15, 2008 | Toshiba Satellite X205-S9349 Notebook
NetGear DG834G Router Logo
71 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
