Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Slider switch problem
When i move the slider switch from photo through video to the bottom position, the camera does not register that the slider is in the bottom position and stays in video mode.
  • jenny1974 Jan 13, 2008
    I have a similar problem. The slider switch is stuck on 'view pictures'. Something to do with my two year old dropping the camera on a stone floor. Oops.
  • Berni2094 Feb 02, 2008
    I have same prob Switch in photo mode to video ok then down to playback and stays in video mode - cant download pix
    Ixus 60
    Genius:
  • 2,985 Answers
Switching probel- may be repairable - check out Canon for estimate- but don' hold your breath
Posted on Sep 04, 2007
Fix memory error message on camera
Hi there! Make sure the SD card is not locked. There is a tiny slider on the side. If is in the "down" position, the card cannot have new files saved to it. Move the slide to the "up" position, then reinsert the card.
If the slider is very loose, it's possible that inserting it into the camera slides it down, essentially making it useless. I have one like that. You could try a touch of superglue to make the slider harder to move, but I have never tried this and you would need to be very careful not to use too much, and to make sure it's entirely dry before putting it in your camera. Perhaps try a different memory card?
Nov 04, 2014 | DXG 518 5 Megapixel Compact Camera -...
I have a nikon coolpix. It is continuously showing 'MEMORY CARD IS WRITE PROTECTED'. I cannot take any photos. Please help.
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 17, 2012 | Nikon Coolpix S50 7.2 Mp 3x Optical Zoom...
We purchased this camera for our grandson, the problem is the camera appears to be locked. you cannot take photos,in fact alll you can do is turn the camera on. the instructions got colored on sao they...
Hi. I don't know this camera but if it uses a memory card it could just be that the card is 'locked'. Have a look at the card and move the little slider to unlock it.
HTH
Chas
Mar 06, 2011 | Sakar Crayola EZ Grip Digital Camera
The massage " protected card
You probably need to move the little slider lock on the memory card to 'unprotect' it
Dec 11, 2010 | Cameras
Will not go onto to the copy mode whilst trying to retrieve photos off clipboard
Checklist: Turn mode dial to clipboard...slide switch to playback...press menu button...if clipboard does not contain pictures, then "copy" will be grayed out.
Oct 01, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
I cant take delete, or move photos from my sd card, If i try to do anything with the images on the card when its plugged in to my computer a pop up comes up saying 'Cannot move 4267_180627790516_589680516...
is the card lock slider on? look at the card, there is a tiny switch that says in tiny letters lock, is that moved to the lock position? the little slider is on the left side of the card with the SD Logo label
May 07, 2010 | PNY 2GB microSD Memory Card
Card locked can't take a photo
This is usually caused by the SD card, and is rarely to do with the camera. On the SD card there is a small slider - which allows you to lock the card (to prevent accidental erasure).
If you put in on the table with contacts upwards, corner cut top left, then the slider is on the right hand edge, about 1/3 the way down. If it is slid to the top position (nearest the contacts) the card is unlocked. If it is slid down (away from the contacts) the card is locked.
If it is a damaged / "cheap" card, sometimes the slider falls out, in which case the card is locked. You can still read from it, but not write to it until fixed or replaced.
First check is to turn the camera off, remove the card, move the slider to locked, then back to unlocked. Replace in the camera and turn on.
Have you tried the camera with another SD card, to see if the problem persists? (A reputable photo store will often lend you a card for the 20 seconds it takes to do this test)
Mar 10, 2010 | Canon PowerShot A510 Digital Camera
Camera is locked
On the side of the card is a small yellow or white slider switch, move it back to the other position then try the card again.
Sep 07, 2009 | Cameras
Memory Card locked unable to release it
-see response above
-but in short...
1- find tab/slider ...move to other position
2 if tab/slider is broken...then cover the opening with clear tape to fix
Oct 07, 2008 | Samsung Digimax L830 Digital Camera
Open Questions:
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
