The first thing is to always remove the batteries, wait 15 minutes and replace the batteries with fresh new ones.
If that doesn't work you can try cleaning the remote with a wet cloth, and then switch cleaning spray to ensure the problem isn't a stuck key and dirty switch contact.
If that doesn't work, just order a copy facsimile remote made for the television. They are cheap enough and need no programming
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
I put the tv on av to watch a dvd. I now want to watch tv and it will not change from av to tv. I have a universal remote and it does not register of when I put it on tv it goes back to av
that remote don't support your insignia , you can get one that supports your insignia and the features of your insignia for about $15-$20
hope that helps and thanks for using fixya!
I have a similar problem. The remote works for 5 to 10 minutes then no longer works. If I take the batteries out of the remote for 10 minutes (or longer) and reinstall them, the remote will again work for 5 to 10 minutes. I got a replacement remote from Frys and it behaved the same way.
Unplugging my TV for 15 seconds (longer actually - at least a minute) made the remote and the satellite TV remote both work again with the TV. Thanks for the tip!
Why not invest in Nikon's Camera Control software. When the camera is attached to a laptop, you have complete control of the camera from the computer, and it will do time-lapse shots at any interval you choose.
