Question about Konica Minolta magicolor 2300DL Laser Printer
How do i change a black cartridge ona Magicolor 2300DL? The black toner is shown as empty but the menu only allows me the options of changing one of the color cartridges. Black is not mentioned
On the front display of the printer press menu and use the arrows to scroll to engine. press menu/select again and scroll to "replace toner". menu/select again and scroll to the colour you need.
Posted on Dec 13, 2007
  • Konica Minolta Master
  • 691 Answers
Black is listed as K. CMY (Cyan Magenta Yellow) K (Black)
Easiest way ids to open the fron door, remove the toner bottle and poke a screwdriver in the small round hole near the toner opening. This will free the carousel so you can move it to whatever colour you want to remove.
Posted on Oct 13, 2007
Thanks...your a life saver...KIIm
Posted on Feb 20, 2008
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Mar 13, 2010 | Konica Minolta magicolor 2300DL Laser...
Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
Jan 13, 2010 | Konica Minolta magicolor 2300DL Laser...
The instructions for this are posted on inside, back-left of the front panel when open. As indicated, push the green button in the lower-left corner with an embossed "1" next to it. Then, turn the green knob next to it with an embossed "2" next to it until the next cartridge is fully visible and the button from step 1 pops back out. Repeat step 2 until the correct cartridge is in place. Then pull the green handle above and to the left of the cartridge.
Aug 09, 2009 | Konica Minolta magicolor 2300DL Laser...
Trying to change black toner but can only get blue out, cant get to the black one
There is a button you can press to free the carousel, and turn it round to show the black cartridge, it is located to the left of the carousel opening just under a little picture showing how to get the toner cartridge out, any problems email me on derekkneeshaw@yahoo.co.uk I will send you a photo of where the button is
Delboy
May 06, 2009 | Konica Minolta magicolor 2300DL Laser...
Black toner
Go into:
menu, engine, change toner, choose cartridge...
Dec 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Printout getting fainter magicolor 2300dl
Probably low toner if fading is on black only or a single color. To check levels, MENU (right arrow to Consumable Usage) MENU (right arrow to see each toner cartridge level) Readout may not be accurate, especially if you have changed or removed a toner cartridge.
Dec 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Replacing Black Cartridge
You can change the toner by going thru the menu, and selecting the appropriate "change black toner" item. I've got the same printer btw. You then open up the cover and the black toner has been rotated to allow you to remove it.
-gary
Mar 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Cartridge Removal 2300DL QMS Minolta
magicolor 2300 DL procedures
a)From the display, select the menu “Engine”.
b)Select “Replace Toner”.
c) Select each color toner cartridge from this
menu to remove it.
Nov 26, 2007 | Konica Minolta magicolor 2300DL Laser...
Toner cartridge end of life message
Go to the menu on the physical printer. Go through the selections until you see it say change print cartridge. Follow until you see to change the black one.
Dec 07, 2006 | Konica Minolta magicolor 2300DL Laser...
Konica Minolta magicolor 2300DL Laser Printer Logo
582 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
