Question about Whirlpool GH6178XPS Microwave Oven
Whirlpool mh2155xps microwave door handle
I need to replace the handle on my microwave. I can not get to the screws inside. I took the 3 screws out of the side but it has a stainless steel front that needs to come off with tabs that fit into the plastic part that goes around the door. I can not bend the tabs to get it off. I can not find a way to open it up. Any help?
  • Whirlpool Master
  • 9,174 Answers
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 Your model does not show up. You can double-check it or look up model MH1150 - it should be close enough to help you see how it works. You may need to remove the choke, as shown in the attached sample drawing.
Posted on Sep 22, 2007
SOURCE:
How to replace the door handle on a whirlpool MH2155XPQ micro wave
The screws that hold on the handle are inside the door assembly. Here is the way its done but its not for the average person. On the inside of the door is a plastic frame all the way around the door. It is held in place by plastic tabs. You have to gently pry off that frame with something like a putty knife or small screw driver. If you are not careful you end up breaking off some of the tabs. Once that frame is off you should have access to the 2 screws holding on the handle. Remove screws---replace handle---and push plastic frame back on.
Jun 26, 2015 | Whirlpool MH1150XM Convection/Microwave...
Trying to replace handle on door,removed three screws on side of door unable to remove inside panel
Most microwave doors are just clipped together with plastic tabs.To remove the inner door panel you need to carefully pry the plastic frame off the inside with something like a small screwdriver or putty knife. Even being careful you may end up breaking the tabs or frame. Once the inner frame is removed you should be able to get to the handle screws. I'll try to attach a picture of the door breakdown.
May 09, 2015 | Whirlpool MH7140XF Microwave Oven
I have a whirlpool mh1150xms-3 and the handle is broke! how do i replace it without breaking the glass? i took out the 3 screws on the left side and it wont seperate from the outside case!
Unplug the microwave oven from its power outlet or turn off its circuit breaker. Remove the right fuse from the home fuse-box if your microwave is a built-in model.
Open the microwave door and take the top pin off its pivot bracket. Lift up the door and remove it from the bottom bracket. Lay the microwave door with its front side down on a folded towel. Remove the two choke screws from the door frame using a Phillips head screwdriver.
Remove the choke cover with the knife blade, starting from the microwave door's top right corner. Pry out the bottom and top right sides, leaving the side which houses the door handle in place.
Remove the choke tabs from their slots on the microwave door frame using the knife blade. Continue to work clockwise around your microwave door; remove the choker cover when you get to your handle's side to separate it from your choke.
Remove the two handles with the Phillips screwdriver. Remove the handle from the microwave.
Screw the new handle in the position of the original handle. Lay the choke on the microwave door; set the choke cover right on top of it. Insert the choke tabs into their slots on the microwave door frame using the knife blade.
Secure the two choke screws using a Phillips head screwdriver; set the microwave door back on the bottom bracket. Slide the top pin into the microwave's pivot bracket.
Press the top pin down until it pops securely into place.
Oct 03, 2011 | Whirlpool MH1150XM Convection/Microwave...
How to replace door handle on whirlpool microwave model MH2155XPS-0
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. Several of these sites also have helpful exploded view parts illustrations to assist you with parts identification and how disasemble/reassemble your appliance. A replacement part number for the model you have listed is 8169738.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges. You may have to remove the grille cover located above the door on some models to accommodate being able to lift the door.
If you have any questions, please post back and let me know. I hope this helps you.
Apr 21, 2011 | Whirlpool MH2155XP Microwave Oven
HOW DO YOU REPLACE HANDLE ON A WHIRLPOOL MICROWAVE. DO I NEED TO PRY BACK THE CLIPS ON INSIDE FRAME.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 29, 2010 | Whirlpool MH2155XPS Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven Door Handle Replacement
You shoul take off the hole door, use something like a flat screw driver and wedge the plate off.
some of the mics got tamper holes where it hooks in.
Hope it works...
Sep 09, 2008 | Whirlpool MH7155XM Microwave Oven
Microwave problem turntable spinning after replacing door switches
Make sure the switches are connected EXACTLY as the original ones, maybe one was connected incorrectly. It also can be the controller board.
Feb 16, 2008 | Whirlpool MH2155XPS Microwave Oven
Whirlpool mh7130xez-1
When you open the microwave door, on the inside of the door there is a plastic trim around the glass called a choke that is clipped in that needs to be removed to get to the screws for your handle
Oct 29, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool GH6178XPS Microwave Oven Logo
309 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
