Question about Uniden BC92XLT Handheld Scanner
Software I bought a little device from Radio Shack, an adapter of some sort to connect the scanner to my computer and quick,easily, and efficiently get codes on my scanner,and organized BUT when I purchased the deal I didnt realize the software WAS NOT included. I read reviews about the adapter I bought and they were all pretty good, except for the same obstacle I ran into. Where/what software is compatible with my BC92XLT?
    New Friend:
Use hold 1113698x32
Posted on Jul 04, 2011
  • JMFTACTICAL Jul 04, 2011
    ***I need help getting a code to enter to get police when they say "switch over" a code to scrable
I Have a pro433 from radio shack im trying to use a pc wire to download the trunked channels, but i just cant get the wire to work if anyone can help il appreciate it
Posted on Feb 06, 2008
    Scholar:
  • 142 Answers
I would try going online to the manufacturer's website to download the drivers (software) there. Even when the software is bundled with any such product, it is always best to check with the manufacturre's website to make sure your software is up to date.
Posted on Sep 04, 2007
2 Suggested Answers
SOURCE:
  • 218 Answers
SOURCE: Software for Uniden BC92XLT?
Unfortunately the BC92XLT does not support computer programming. It was replaced by the BC95XLT which does support this.
Posted on May 28, 2009
Outside antenna adapter to put on the scanner
Radio Shack can help you get the right adapter.
Jan 23, 2014 | Uniden BC244CLT Base Scanner
Two years old..Will not turn on when plugged in
Radio Shack have a Device sort of an adapter that works great with it , also u need to check on the car/truck fuse or just simple get a new adapter from radio shack
Sep 22, 2011 | Garmin Nuvi 660 GPS Receiver
How do you program a radio shack to the 700mhz trunking chanels
You will probably have to use a '3rd party' SOFTWARE package. Mr. Donn Starr has written software for most of the GRE / Radio Shack scanners, and using his software will usually allow you to enter 700MHz frequencies. You will need the USB Scanner programming cable and software from Radio Shack, then search online for a link to get Don Starr's software. You might be able to try it out for free for a little while, but it is really worth the $30 for how easy it makes it to program your scanner once you get the doggone Radio Shack USB scanner programming cable configured to work with your computer. Let me know if you have more questions.
Mar 11, 2011 | Radio Shack Pro-2096 Base Scanner
I need to rebanc my pro 96 and bought the programming cable and driver software item 20-047 (or 200-0047) and trying to find the driver for my computer and the users manual; neither of whic are on the cd....
Radio Shack no longer sells the frequency software for this scanner. the drivers for your computer are on the cds you have so hold on to them they also are no longer available. radioreference.com may have the software for programming
Jul 16, 2010 | Radio Shack Pro-96 Scanner
Need adapter/charger
Radio Shack no longer markets a charger/adapter made specifically for the PRO-82, but the 6-volt Enercell AC adapter with a size C Adaptaplug will work with your scanner. Radio Shack total retail for the pair is $30, and you can probably find them on line for even less. You might even luck out and find a compatible 6v wall wart on eBay.
Bill B
Mar 08, 2010 | Radio Shack Pro-82 Scanner
Not getting any power
Ok, are the batteries fresh? Did you make sure they are installed correctly? Have you tried an AC adapter plugged into the side of the unit? This bypasses the battery compartment and may work, indicating the problem area is within the battery compartment and or its wiring. I'd take it to radio shack and see if they will give a quick opinion, mabye letting you try a charger before you buy. Also, if nothing works, Radio Shack repairs Their scanners, often for a very reasonable price. been there, done that. Bst of luck!
Jan 30, 2010 | Uniden BC60XLT-1 Handheld Scanner
Programing a uniden BC246T
Not all programming software supports usb. Either find software that supports usb or you can buy add on cards to your pc that will give you a serial port. Hope this helps
Jan 26, 2009 | Uniden BC246T Handheld Scanner
Programing
Here is the online programming tutorial:
http://support.radioshack.com/support_tutorials/communications/200-0523/67345.htm
Here is the full manual Should include Quick guide:
http://support.radioshack.com/manuals/ome20-525.pdf
Here is FREE programming software for the PC:
Includes hardware info. You can buy programming cable at Radio Shack to connect to your PC.
http://www.starrsoft.com/freeware/win95/default.asp
Hope that helps...
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 29, 2008 | Radio Shack Pro-95 Handheld Scanner
Computer Interface
Rat Shack say they will load your scanner at no charge . The program is called Scan Cat I think .You can get the program on the net .Every Rat Shack has the program on the store computers . The 94 is not a bad scanner .Hope this helps .
Apr 19, 2008 | Radio Shack Pro-94 Scanner
Pro 97 radio shack
hi if its not digital you cant prgrame it in sorry mick
Jan 01, 2008 | Radio Shack Pro-97 Handheld Scanner
Uniden BC92XLT Handheld Scanner Logo
248 people viewed this question
Top Uniden Radio Communications Experts
Jason
Robert McClure
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
