My sharp vl-ah150 view cam works on ac power but won't work in battery mode. the battery tests at 3.6 volts at the pos. and neg. prongs on battery. What is the t terminal on the battery?
If the 6 volt batteries are wired neg to pos to neg to pos to neg etc, then do the same with tha 12 volt batteries. So neg on one to pos on the next, then neg on that one to pos on the third. (- +) (- +) (- +)
AC Adapter/Battery Charger UADP-0312TAZZ (VL-A10U/UC/T/AH30U/UC/T) UADP-0313TAZZ (VL-A10UA/UW)Power Requirement: AC 110-240 V, 50/60 Hz (CSA certifies AC 120 V only) DC Output: 7.0 V Power Consumption: 15 W Dimensions (approx.): 211/16"(W) × 115/32"(H) × 518/13"(D)
Have you tried flashing your generator? Sometimes the magnets in the generator loose their polarity. Google and YouTube "flashing a generator" HFLASHING the GEN
Sometimes the magnets lose their polarity. This worked on my brothers $1200 gen. Its worth a try. Good luck! Check all wires/connections first, Then try this- (Remove spark plug wire first!) To flash the field on a small home use generator, get an ext. cord & cut off the female end of it & strip the wires & connect the wires to a 12 volt car or lawn tractor battery, & plug the male end of the cord, into the 120 A.C. side of the generator.
Make SURE that the black wire which is POS/HOT on an A.C. cord, gets connected to the RED/POS. side of the auto battery, & the white wire on A.C. cord gets connected to the BLK./NEG. side of the battery. If the ext. cord wires are not black & white, then the smaller prong of the plug is the POS./HOT
Plug the other end of the ext. cord into the generators 120 volt side (**remove spark plug wire**) & pull the starter cord 4-5 times, then remove the ext. cord, reconnect the spark plug wire, start the unit & plug something of 120 A.C. volts in to see if it works. Then let it run for about a half hour with 2 - 150 watt lights to help re-generate the unit.
Read more:http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/188605-recharging-generator-field.html#ixzz29QwjlAOWere's one way-
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
It sounds like possible bad batt cable or connection as it takes a bit more batt power when engine is cold to crank engine. if you have a volt meter, you can check this. set to volts dc and put one lead on batt neg. post and one on engine block, crank engine, in theroy you should not see any voltage but if you do, that is whats lost in neg cable, in my exp. you will see about .5 volts if you see too much more than that, i would be looking at cable. you can do same thing on pos. side but keep in mind if you go from batt pos. to large stater pos. at stater and you have a ext. sol. like ford likes to use that your loss could be in the sol. contact as well. And under cranking mode your batt should drop to no less that 9.6 volts under load and thats tested at batt post.
To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor. This is only a solution for 3 battery system. For 4 battery system, connect 4 to 3 pos to pos and neg to neg. [email protected]
Or check the battery with a DVM(digital volt meter).
Or get some batteries and connect in series to equal to that voltage and use two wire leads. One lead to -negative side of the battery, other lead to +positive. Now, -neg to neg of camera and +pos to pos of camera.
You now have power to the camera to test. This will save money rather than buying the camera's battery for testing. AA, C or D will work, just look on the camera's battery to see the right voltage.
Examples: with two batteries (1.5VDC + 1.5VDC = 3..0VDC). So -(negative) of one battery to + (positive) of the second battery with solder.
-(-neg, battery, pos+) solder to -(neg, 2nd battery, pos+)+
left side , use black wire on -(Neg) and solder right side, use red wire on +(Pos) and solder.
Now you have two leads, use those to connect to camera.
