Question about Jensen AM/FM/MP3/DVD/CD iPod-Ready Receiver w/ 7" Motorized LCD Screen Car Video Player
VM9311TS Subwooofer problem
So I have a 2005 Scion tC and I have the stock sub woofer. I wired everything up yesterday and everything seems fine. All speakers work. My Subwoofer plays when i use the Radio/tuner but when I put in a CD or DVD the sub woofer does not play. Ideas?
  • gsk3rd Sep 04, 2007
    Edit: their is no sound coming from the Sub is what I ment to say.
You wired the remote wire up to the solid blue wire on the dvd need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Posted on Jul 01, 2008
Body control module 2007 scion tc
2007 Scion tC Body Control Module - 1A Auto > 2007 Scion tC
Shop at 1A Auto for a brand new Body Control Module (BCM) replacement for your2007 Scion tC at a great price. 1A Auto has a large selection of Body Control ...
HELP!!! BCM issue 2005 tc -
Jun 30, 2009 - i think i have a possible BCM (body control module) issue with my 05 tc, ... Using 2007 Air Box in a 2005 Scion TC, chowdahound, Scion tC 1G ...
2007 Scion Tc Body Control Module - Auto Parts Discounter
Dec 13, 2015 | Scion Cars & Trucks
How do you fix a stuck volume button on scion xb stock stereo?
The only way to fix it is to take it apart and see if it is just jammed or if the button is defective if defective you neeed to replace it they are very small so you need some good soldering skills. Hope this helps.
Aug 21, 2014 | Pioneer 2005-2006 Scion Tc Xa Xb Cd Mp3...
I have a 2005 scion tc, everything stock. My bass just stopped working, the treble still works but there is no bass. Does that mean i blew my speakers? They still sound fine. Is there anything I can do...
check your fuse box and find which fuses go to your radio/audio system it may have a built in subwoofer and amp in the vehicle -check those out and hopefully it will solve it.good luck.
Dec 10, 2010 | Car Audio & Video
I can not eject cd in my 2005 scion tc. Stock single cd player
cut off the raido and car try to stick two idcards, one on top of the cd one on bottem, squease them together and pull the cd out. if it has a paper lable on it dont put it back in.
Mar 08, 2010 | 2005 Scion tC
We were driving my car down the road and it made a banging noise and just turned off...what could it be and is it expensive to fix? 2005 Scion TC
sounds like it needs a motor... check your oil and coolant... motor either ran out of oil or overheated either way the engine is probably smoked... most engine jobs run around 5000 dollars
Jul 16, 2009 | 2005 Scion tC
The sunroof on a scion tc 2005
My best bet is its your Sliding roof drive gear sub-assembly. I would also check your sliding roof control switch and you wiring harness. In fact i would check those those first since they are the fastest to check and then that only leaves your sub assembly. you will need to remove your headliner to test everything. And you will need a volt meter that you can get for a couple bucks at most electrical stores. use your volt meter to make sure your getting the same amount of to power to your switch as your getting just past it when it is closed. then test the wiring closest to your motor with the switch closed and there a very minimal amount of volts lost. If everything checks out i would go with the sub assembly. Hope this helps.
Jul 09, 2009 | 2009 Scion tC
Sub jacks play but door speakers wont play when hooked up to proper wires why
your car has a stock amp for the speakers hook up the blue wire that is on the stock lead wire harness to the remote wire along with the remote for the amp
Jun 29, 2009 | Audiovox VM9311TS
Can a 2006 Scion Tc cd player fit into a 2005 Scion Tc?
yes its the same plugs but you wont have the steering weal control
Jan 17, 2009 | 2005 Scion tC
Car Audio & Video Logo
135 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
