Question about Panasonic (CF61-TPAD) for Toughbook CF-61 (CF61TPAD)
Re-panasonic cf-61 hiya sorry to be a pest your tips were helpful but i cannot find a connection on the laptop to connect to the internet like an earthnet cable can you help plzzz
SOURCE: panasonic laptop cf-61
I found these links below they should be of some help... gr/bkrwlaptops.htm
Posted on Sep 04, 2007
0 characters
1 Points
How do i obtain a internet password
There are no internet passwords. For lot of internet related services you need passwords. Like when you want to setup a wireless connection, you have to setup your wifi router with a wireless connection the connection gets a name and if you are wise you secure the connection with a password. Same goes for every mail account or accounts on websites. You need an unique login name and to make sure no one els can access the account secure it with a password.
Apr 19, 2015 | Azpen Innovations Azpen X1 10.1-inch...
Will not connect
what connection and numbers what numbers are you referring to ?
internet connection ?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 14, 2013 | PANDIGITAL Android 2 GB 9Inch Multimedia...
Panasonic interactive whiteboard won't project computer
If you'd like to email me at I'll be able to help you in more detail. There's a fundamental error to the question here. That is the board in itself will not show the image - your boards is effectively a large flat mouse. A pointing device infact. The peice of equipment that "shows" your PC image is actually the projector. There could be several reasons why your projector isn't showing the image.
1 - is there either a VGA or HDMI cable connected from your laptop/PC to the projector (Sometimes via a wall plate).
2 If 1 is true and the projector is turned on does it show any sort of image? Now there are two thongs you can do from here. a) If you have a laptop check to see if your Video settings are set to clone across to a secondary monitor on most laptops you should hold down Function key and F8 this will toggle through three options Onboard screen remote screen and then both. there could be some lag between the two so hold down fucntio at the same time press F8 then wait a few seconds then go again.
Finally on you projector remote there may be an auto search buttion which will hunt for your PC image by checking each of the Projector inputs in turn. Generally speaking however you should select "Computer 1" or sometimes named as RGB 1
Hope that helps email me if your still having problems.
Aug 21, 2012 | Panasonic Panaboard Ub-T880 Interactive...
Connecting acer c100 to internet
hi, have you added the device (c100) to the router access list under wreless settings , the clue would be a yellow dot or triangle in the wireless logo on the c100 showing restricted access?
Jul 07, 2012 | Acer (91.48R28.006) for TravelMate C100...
My arrow is frozon on screen,for the compaq 61.nothing seems to work thanks
First of all connect the usb mouse then try to uninstall touchpad driver and then install it again.
Oct 07, 2010 | Compaq (153515-001) Touch Pad
you can download here:
Sep 10, 2009 | Panasonic Panaboard UB-5315
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Panasonic cf-61 is password locked
Firstly is it the password immediatly u switch on or when loading windows, if it during loading of windows unless reinstall windows again and select repair while installing just after pressing F8 in EULA screen
or if its a BIO's password try this:
WARNING: U need to see a technician be remove the password, if its a system password in the BIO'S setup. if u can and thats if u are sure you can do the following.
1. Open the computer system unit
2. On the motherboard locate for a jumper written clear CMOS
3. remove the jumper and switch on the computer.
4. Switch it off again and replace the jumper back.
Note that the setup configaration will go back to default settings, so any other settings u had done u have to redo again
Mar 01, 2008 | Panasonic (CF61-TPAD) for Toughbook CF-61...
Panasonic laptop cf-61
Sep 03, 2007 | Panasonic (CF61-TPAD) for Toughbook CF-61...
Graphics Tablets Logo
21 people viewed this question
Top Panasonic Graphics Tablets Experts
Gareth Cockram
Gareth Cockram
Are you a Panasonic Graphics Tablet Expert? Answer questions, earn points and help others
